PineTime Sleep Tracking
I'd guess it's down to whether infiniTime exposes the heart rate over BLE in the format that Sleep As Android requires since there seems to be more than one protocol. These issue reports may give you some guidance. Unless I've misunderstood the question...
https://github.com/InfiniTimeOrg/InfiniTime/issues/895
https://github.com/InfiniTimeOrg/InfiniTime/issues/749
My limited understanding of how Fitbit derive sleep state is through movement and variation in heart rate, they mention HRV changing as you transition through sleep stages.
This lets them calculate sleep stages with only an accelerometer and optical heart rate sensor and it appears their method of tracking sleep stages is between 75% and 80% as accurate as compared to a head mounted EEG.
So yeah, you don't need much to get a lot out. Would love to be able to integrate ML into the data processing, perhaps have a calibration period where you wear a sensor along with an EEG to improve accuracy through training.
Hey folks, I’m super new to Pine Time and wanted to figure out what I need to get started - would love to try and figure out sleep detection using accelerometer and HR data. What’s the simplest way to get it - should I buy a regular Pine Time or a DevKit?
Things I’d like to build:
- Sleep detection
- Adaptive alarm (wake me up if I experience REM between 7 and 8am)
Ideally I’d have the watch send the telemetry wirelessly to a server (maybe a Raspberry Pi) that will interpret the data and tell the watch if any action is required (eg buzz).
Does infiniTime offer this as is or do I need to hack it?
  Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 3 5,347 06-06-2026, 03:33 PM
Last Post: oscar-gardiazabal
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 5,217 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 4,392 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 11,354 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 6,352 07-30-2025, 11:44 PM
Last Post: karthick
  PineTime charging issues - connecting pins black gsoundsgood 2 4,558 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 7,432 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 11,730 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 7,552 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 2,979 01-31-2024, 11:57 AM
Last Post: tynstar
