Axolotl on PinePhone / Mobian
(04-14-2022, 03:16 PM)arno_nuehm Wrote:
(04-14-2022, 02:10 PM)ragreenburg Wrote: Arno, I sent you some logs for Axolotl not working for version 1.2, anything else you might need?
Thanks again for your logs and good news: Help is on its way.
Signal might have changed an URL in their system and nanu-c (Axolotl main-dev) will look into it tomorrow.
Sounds good!
FYI
There is a syncing problem with Signal Desktop and Axolotl for some user at the moment: Messages sent via Signal Desktop do not appear in Axolotl - and vice versa.
(08-09-2022, 02:10 PM)arno_nuehm Wrote: FYI
Not sure if it is related, but I have a weird issue recently with axolotl.
I have 1 group that has pretty low traffic and members. Up till end July I got the name of the group member who had sent the message at the top of the message. Since 3 Aug I just get the messages but no indication who wrote them.
A second issue'ette - I am still running axolotl 1.2.0-1. I note there is arguably a v1.3 but it has no arm64.deb - not sure if it would change my life?
Thanks for posting that issue - I have the same problem and will write a bug issue.
And yes, v1.3.0 (deb) ist not officially out, because the github workflow had some problems - the heat I think.
I will look into that, too.
Cheers!
The github workflow is fixed - here is the deb-package for 1.3.0 (officially 1.3.1)
https://github.com/nanu-c/axolotl/releas..._arm64.deb
Cheers!
P.S.: Syncing problems are not fixed yet.
Installed the new version today, worked fine. Thanks arno! Smile
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
nanu-c did a lot of work in the last couple of days and v1.5.0 is out. Signal is changing the handling of sender identifiers at the moment, that's why names haven't been shown in groups lately - which is fixed now.
Here is the download link
Cheers!
(08-23-2022, 04:17 AM)arno_nuehm Wrote: nanu-c did a lot of work in the last couple of days and v1.5.0 is out. Signal is changing the handling of sender identifiers at the moment, that's why names haven't been shown in groups lately - which is fixed now.
Cheers!
Looks great to me - thanks & to @nanu-c
Going through motions here, to get this installed on Manjaro Phosh... what I found is that I need dpkg to be able to install a .deb file, but when I try to install that, it complains about two glibc related files missing. No idea how to get those (and why doesn't it find them by itself). Tried to install apt, and pacman doesn't find it.
Any Manjaro compatible package that would just install, or a pacman address?
(09-04-2022, 06:50 AM)Eugo Wrote: Going through motions here, to get this installed on Manjaro Phosh... what I found is that I need dpkg to be able to install a .deb file, but when I try to install that, it complains about two glibc related files missing. No idea how to get those (and why doesn't it find them by itself). Tried to install apt, and pacman doesn't find it.
 the aur package is 1.2.0-1 so tomorow i'll try to change the PKGBUILD to the latest version and see if it works
ezik
  Printing from Mobian johnd 3 5,133 10-27-2026, 06:01 AM
Last Post: PrinterSolvedTeam
  Mobian MMS/SMS text problem bcnaz 16 41,091 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 2,114 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,824 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 75,342 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,623 06-29-2025, 12:38 PM
Last Post: Hiraghm
  VoIP account on mobian dialer j_s 0 3,304 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,568 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,306 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 5,004 04-29-2025, 02:10 PM
Last Post: mdk
