NVMe drives not detected
Thanks for the reply, the image link is broken though Sad
My Patriot P300 turned up and worked (before I decided to reinstall my PBP)
Interesting. I've still had no luck with the taping. I may try things out with the case open but that isn't recommended/decidedly awkward.
I have a similar yet different issue in that my Toshiba XG5 256GB is detected in lspci, but not in lsblk.
According to https://wiki.pine64.org/index.php?title=...SSD_drives the XG6 should work, so I was hoping my XG5 would also.
2024-11-18 05:56:15 root@pinebook-pro:~# lspci 00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3399 PCI Express Root Port 01:00.0 Non-Volatile memory controller: Toshiba Corporation XG5 NVMe SSD Controller 2024-11-18 05:56:19 root@pinebook-pro:~# lsblk -o +label,fstype,uuid NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS                                               LABEL      FSTYPE UUID mmcblk2      179:0    0 115.2G  0 disk                          ├─mmcblk2p1  179:1    0 457.8M  0 part /boot  BOOT_MNJRO vfat   FAA6-62B5 └─mmcblk2p2  179:2    0 114.8G  0 part        ROOT_MNJRO ext4   cb4bda28-8512-47f6-a41b-847eb1471baa mmcblk2boot0 179:32   0     4M  1 disk                          mmcblk2boot1 179:64   0     4M  1 disk                          mmcblk1      179:96   0 119.3G  0 disk                          ├─mmcblk1p1  179:97   0 457.8M  0 part        BOOT_MNJRO vfat   FAA6-62B5 └─mmcblk1p2  179:98   0 118.8G  0 part /      ROOT_MNJRO ext4   cb4bda28-8512-47f6-a41b-847eb1471baa zram0        253:0    0   5.7G  0 disk [SWAP]                   2024-11-18 06:00:17 root@pinebook-pro:~#
EDIT: I'm also annoyed that the NVMe is more difficult to swap than it really needs to be. The screw holding the NVMe to the sub-board should be easily accessible instead of removing the entire sub-board to then remove the NVMe.
Did you see my post immediately below?
skysmotor.co.uk sells the following products online: dc servo motor, geared stepper motor, stepper motor drivers, planetary gearbox and can be purchased online if required.
I also used the Wiki and taped my cable down; The power consumption was a lot so I eventually removed it.
PinePhone, Pinebook Pro & PineTab2 owner.
(12-19-2024, 12:46 PM)dachalife Wrote: I also used the Wiki and taped my cable down; The power consumption was a lot so I eventually removed it.
Probably you don't, but do you have any kind of benchmark comparison?  I never installed mine because I figured it would use too much power.
:wq
It was really noticeable on battery, no benchmarks though. Once I hit 48% battery it was time to shut down. This was with a Samsung, on power/docked it worked fine.
(12-24-2024, 12:39 PM)dachalife Wrote: It was really noticeable on battery, no benchmarks though. Once I hit 48% battery it was time to shut down. This was with a Samsung, on power/docked it worked fine.
I have 3 (well 2 are mine and the 3rd I guess I'm responsible for fixing when it Linuxes); and the older two, one mine, have terrible power management.  They never get to 100%, never have.  They don't actually charge with the display on, the discharge just slows down (a lot).  The third, (newest,) has never had these problems: it charges quickly even if the CPUs are overclocked, and will reasonably reach 100%.  I'll find out soon if this was battery related: I have to replace all three; they have expanded to the point of breaking the hinges!  But I suspect not because that one is the ’new’ main board design (at least was when it was new).
So anyway I wonder if that matters.  I suppose I could buy an NVMe "drive" to see.  Though I most likely cannot afford one at the moment.  Alas, I did just buy $90 of accordion parts I didn't really need.  Confused
:wq
  NVMe reukiodo 0 3,044 11-18-2024, 09:00 AM
Last Post: reukiodo
  New Working nVME gilwood 1 4,542 11-17-2024, 04:24 AM
Last Post: reukiodo
  NVME problems 2022 / Intel 660p 1TB Starbug 1 5,779 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 5,456 11-28-2022, 12:56 PM
Last Post: dachalife
  NVme intall usage? tkudog 2 6,416 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 4,574 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe SSD testing methodology halogen 1 5,708 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 10,626 07-09-2021, 08:45 PM
Last Post: moonwalkers
  nvme drive disappears after about an hour of uptime codebreaker 24 60,607 02-09-2021, 11:32 PM
Last Post: dsimic
  Speakers not detected PineHead7 1 5,411 01-07-2021, 01:50 AM
Last Post: ab1jx
