Armbian on Quartz64
#31
if buildroot is to bleh
here is a debian one Smile
https://drive.google.com/file/d/1dvycdIN...sp=sharing
(02-13-2022, 04:43 AM)mulimoen Wrote:
(02-13-2022, 04:09 AM)shaggy013 Wrote: here a booting image for quartz64 with hdmi Smile
it is just the last 5.10.66 kernel and the 1560 uboot with my quartz64 dts with 4 reverted patches  ,
hdmi ,usb, lan ,wifi  works pcie not tested , only mpp and rga3 dont play nice well
so in rockchip_test the gl mark works the video test you see the mpp and rga trouble
pcie does not work, trying to interact with a nvme ssd gives these sorts of errors
[  612.305740] nvme nvme0: I/O 21 QID 0 timeout, completion polled
[  613.764898] ITS queue timeout (5504 385)
[  613.764935] ITS cmd its_build_inv_cmd failed
[  675.451335] nvme nvme0: I/O 22 QID 0 timeout, completion polled
proberly  "pcie not tested " Smile
it works but didnt apply the patches for it yet
this is just a bsp image with a 5.10 with hdmi
got just posted a debian also Tongue
yocto build will take a little more time have to start a clean build Sad
it are just the bsp images you could make from a rockchip sdk (not the empty one )
if you look at the npu that throws also a lot of errors Smile
well you got at least sata ,usb ,lan ,wifi proberly no bluetooth Cool
Doing some experimentation I can see the device tree from pgwipeout can be used on the 5.16.2 kernel from @balbes150. This makes the nvme drive usable. Hopefully this work is included in a future kernel
Good news. I recently received a sample of Quartz64. I have added CSC level support for Quartz64a to the ArmbianTV build system, after checking and testing, I plan to send a PR with these changes to the official Armbian build system. Smile
The first test images for Quartz64 can be found at the link.
https://disk.yandex.ru/d/xMVoaZXFFcWuog
(03-13-2022, 11:04 AM)balbes150 Wrote: Good news. I recently received a sample of Quartz64.  I have added CSC level support for Quartz64a to the ArmbianTV build system, after checking and testing, I plan to send a PR with these changes to the official Armbian build system.  Smile
Awesome and thanks.
Awesome and thanks.
IMHO this topic can be closed, up-to-date information on Armbian support for Quartz64 is in a new "clean" topic.  Smile
https://forum.pine64.org/showthread.php?tid=16312
  USB on Quartz64 Zero litbulb 1 2,514 07-22-2026, 02:04 PM
Last Post: MichaIng
  DietPi OS for Quartz64 MichaIng 48 61,129 07-22-2026, 01:52 PM
Last Post: MichaIng
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 18,602 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,516 07-30-2025, 07:19 AM
Last Post: pugzarecute
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 152 187,214 03-23-2025, 01:10 AM
Last Post: balbes150
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 91,923 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 5,845 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 4,715 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 5,687 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 11,309 10-29-2022, 06:55 AM
