Powering Pinecil using an Artis 65W laptop adapter
Hi
I recently got a Pinecil. I was wondering if I can use the Artis 65W USB-C laptop charger to power it. The adapter specs is as follows-
Quote:Power Output: 5V/2.4A, 9V/3A, 12V/3A, 15V/3A, 18V/3A,20V/2.25A, and 20V/3.25A, Max Power Output: 65Watts
AC Input : 100V-240V( 50-60 Hz)
Compatible with all type C Laptops
Over Voltage / Over current Protection , Short Circuit/Overload protection, High Temperature Protection
Certifications: CE, FCC, ROHS, BIS (India) Certified.
The 65W charger is able to provide 3.25A @ 20V which seems to be same as the PinePower 120W Desktop Power Supply USB-C output. The manufacture has mentioned that it could be a little too much power for the Pinecil.
Here is the product url-
https://www.amazon.in/gp/product/B095PJY...p_hza?th=1
Here is the manufacturer's reply-
https://www.amazon.in/ask/questions/TxG6...pmw_al_hza
Please let me know.
(01-29-2022, 02:07 PM)werty37 Wrote: The 65W charger is able to provide 3.25A @ 20V which seems to be same as the PinePower 120W Desktop Power Supply USB-C output. The manufacture has mentioned that it could be a little too much power for the Pinecil.
Why would it be too much power?
I assume it is a PD-capable charger, so Pinecil can request 20V and it is able to provide up to 3.25A for Pinecil - generally it should be a perfect fit.
Anyway, 45W charger should be too low to fully utilize Pinecil, as far as I know, its full power consumption is around 60W at 20V.
(For 60W power at 20V, it would need 60W/20V=3A of current.)
Also, basically a power supply can supply a voltage (like 20V) and up to a specified current (A).
So looking at this perspective, the higher current is better and it should work together with Pinecil if it can supply at least that amount of current (or above) what Pinecil need.
So, do not buy a 45W charger for Pinecil.
In this case, actual power (W) comes from voltage (V) multiplied by current (A) and current depends on the device connected and not on the power supply itself (if it is capable of delivering the needed value).
Hi
The manufacturer has confirmed that it is not a PD-capable charger.
https://www.amazon.in/ask/questions/Tx1D...pmw_al_hza
Quote:I assume it is a PD-capable charger, so Pinecil can request 20V and it is able to provide up to 3.25A for Pinecil - generally it should be a perfect fit.
@VaZso Do you still think that I can use it to power the Pinecil and hopefully not damage it?
(02-02-2022, 05:54 AM)werty37 Wrote: Hi
It should be either a QC or PD-capable charger and both should be okay for Pinecil.
For QC, my Baseus chargers needed a timeout setting for PD negotiation timeout which is part of the latest firmware update but it works well by setting this timeout to 15.
As of QC protocol, there are a very few chargers which support 20V over QC (although I have such a charger, so it exists).
However, Type-C capable notebooks work over PD protocol, so if this charger really supports "5V/2.4A, 9V/3A, 12V/3A, 15V/3A, 18V/3A,20V/2.25A, and 20V/3.25A, Max Power Output: 65Watts" as they state, it should be a PD-capable charger (power supply).
However, I am not surprised at anything since I saw there are "notebook chargers" which have 12V output over Type-C connector without any negotiation (they should not exists anyway).
As of seller replies who has recommended a 45W or 30W charger for something which would need 20V * 3A = 60W, I would not think to know too much information about the product to be sold...
If it is either a QC or PD power supply, it should work... but based on the supported voltages, technically it should be one of them (definitively PD for notebooks).
However, it is another question if the power supply is really can provide 65W power output...
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 2,172 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 393 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 811 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 1,017 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,267 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 8,970 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 4,961 05-15-2025, 10:41 AM
Last Post: dreieck
  Pinecil v2 issue autumnharris 0 1,318 05-15-2025, 01:35 AM
Last Post: autumnharris
  Pinecil constantly cutting out WroughtIron 1 2,930 01-16-2025, 02:20 AM
Last Post: D4veC4rter
Exclamation Pinecil is working with 5v but nothing else!! MizterPink 1 2,047 01-07-2025, 03:59 PM
Last Post: MizterPink
