No Application Data PMOS 21.12.1
When I open Software I see no apps and am unable to search for any. I've flashed and re-flashed my pinephone with the latest installer image and the app store still doesn't have any apps. I've also run apk upgrade -a  and apk fix. Neither has worked to fix this. Does anyone have  fix for this or do I need to try and submit a bug report?
I want to know the answer, too.
The closest you can get it to 'work' inside 'Software' I found is to install flatpak:-
sudo apk add flatpak
(of which some applications are working, but not all of it will work. Eg. Giara (Reddit), Axolotl install via 'Software' did not work for me -Giara worked in Ubuntu Touch however)
See also:
https://wiki.postmarketos.org/wiki/Flatpak
(01-20-2022, 11:38 PM)chadwick Wrote: I want to know the answer, too.
See also:
I'll see about filing a bug report. I"m honestly not certain about how to do it though.
(01-19-2022, 08:45 PM)ICaptain1ndustry Wrote: When I open Software I see no apps and am unable to search for any. I've flashed and re-flashed my pinephone with the latest installer image and the app store still doesn't have any apps. I've also run apk upgrade -a  and apk fix. Neither has worked to fix this. Does anyone have  fix for this or do I need to try and submit a bug report?
Same for me with latest stable image. I'm not sure if it's a bug or the intended behaviour? It's definitely confusing for new users
Edit: yeah it's a well known bug: https://gitlab.com/postmarketOS/pmaports/-/issues/785
I find the same issue now, so if anyone could find a solution about this could be really appreciable. Although I install apps from terminal, it would be very useful to have the software app functional.
  Fresh install pmos+phosh does not boot user641 1 3,700 10-08-2023, 04:04 AM
Last Post: user641
Question Always Use Mobile Data DingDangDoong 4 6,617 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  Boots To Shell After Dead Battery (PMOS) britelite 0 2,518 02-17-2023, 02:41 PM
Last Post: britelite
  Disable mobile data auto-enable on boot 64_Tesseract 3 6,202 08-11-2022, 02:48 AM
Last Post: 64_Tesseract
  pmos/phosh edge update and audio disappears robthebold 9 14,746 07-10-2022, 03:26 AM
Last Post: arkadione
  wwan0 (cellular data) ip configuration is POINTTOPOINT not BROADCAST dc2daylight 0 2,651 04-07-2022, 07:16 PM
Last Post: dc2daylight
  Calls don't work on Softbank. Cellular data & SMS work. yasmi 1 3,767 03-24-2022, 04:10 AM
Last Post: yasmi
  Application list PMOS-Phosh jmorris 6 14,185 12-04-2021, 02:26 AM
Last Post: Juergen
  Backup user data and settings kratz00 4 9,011 02-28-2021, 03:39 PM
Last Post: kuleszdl
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 11,155 02-28-2021, 02:20 PM
Last Post: MtnSk8
