I'm trying to install a package that requires the pamac command. At this time, I'm only interested in pamac. I have some familiarity with the existing "pacman" command.
I have tried several tutorials online to install pamac with no success. I can clone the git repository just fine, but get an error after the makepkg command.
Installed git:
sudo pacman -Syyu base-devel git
Created the directory:
mkdir pamac-aur
Listed the directories to confirm:
ls
(All of my directories appeared including the newly created pamac-aur directory)
Changed the directory:
cd pamac-aur
Listed the contents inside "pamac-aur"
ls
(pamac-aur is listed)
Changed into this directory:
cd pamac-aur
Listed the contents of this directory:
ls
(pamac.install and PKGBUILD are listed)
At the command prompt inside this directory, I typed "makepkg" and the process began. It listed some missing dependencies and the process ended with an error.
==> ERROR: Could not resolve all dependencies.
Did I miss something? Can I complete this process with the dependencies acquired automatically? Please correct or add to what I should do to complete the process. Thanks for the help.
I was able to move the process along a little more. I typed in:
makepkg --syncdeps
at the end of this process:
"looking for conflicting packages..."
:: gtk3 and gtk3-mobile are in conflict (gtk3-print-backends). Remove gtk3-mobile? [y/N]
At this point I decided I had better wait for help. I did a "control c" to abort.
Thanks for any help with this.
Installed git:
mkdir pamac-aur
ls
cd pamac-aur
ls
cd pamac-aur
ls
(12-29-2021, 02:23 PM)tk1107 Wrote: I'm trying to install a package that requires the pamac command. At this time, I'm only interested in pamac. I have some familiarity with the existing "pacman" command.
Installed git:
mkdir pamac-aur
ls
cd pamac-aur
ls
cd pamac-aur
ls
makepkg --syncdeps
How to install pamac?
