Kodi on Pinephone
If you look in the software repositories of your Pinephone compatible distro the FOSS app Kodi is probably found if installing desktop apps are enabled.
Kodi is more a framework for plugins from commercial subscription streaming to game emulation and many others, it comes with with a built in multimedia playback capability which can play most media files.
The one difficulty I have found with using Kodi for playback vs any other media player including the stock one in Mobian is that the Kodi mobile skins I have tried to use expect an android home key or something else emulating a backspace.
Is there anyone who has found an easy to use skin for Kodi which provides the missing [back] signal somehow?
Any other Kodi related ideas especially reducing the battery usage for video playback(better utilizing hardware decoding?) would be appreciated!
How easy is it to fork a kodi skin to add a back button? I've not tried, so for all I know there are gotchas along the way.
https://kodi.wiki/view/Skinning_Manual#Button_Control
If it could be made configurable, or autodetect whether to show the button, an existing theme might accept a patch. Some themes have turned down similar requests as they consider it out of scope though ("We target remote controls. If you're using a mouse then pick a different theme." and similar)
(11-28-2021, 04:39 AM)wibble Wrote: How easy is it to fork a kodi skin to add a back button? I've not tried, so for all I know there are gotchas along the way.
Thanks, sadly I didnt see a way to insert a back/backspace into a customized skin.
I hate to follow down the android style route but maybe hacking together a custom keyboard map for multimedia remote controls as a KB option, but then there would be a way to easily control kodi.
There would still be the issue of using up most of the battery with a 1 hour video, same problem if I can coerce VLC to play a video; the stock Totem based Videos player in Mobian has never played a video for me so remains untested, but years ago Totem was one of the first apps I would uninstall.  I suspect this is due to CPU vs GPU decoding of the stream.
  asterisk or FreePBX on pinephone? vanja 0 1,001 06-16-2026, 09:24 AM
Last Post: vanja
  Jami on Pinephone [ IM and VOIP ] p1trson 15 25,908 06-16-2026, 05:02 AM
Last Post: marlboro1950
  Movuan distribution for PinePhone merom 6 8,337 06-04-2026, 02:10 AM
Last Post: merom
  Latest firmware for PinePhone modem! Subsentient 106 249,844 04-03-2026, 08:37 AM
Last Post: baptx
  Fedora + Phosh for PinePhone njha 77 236,535 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,494 11-17-2025, 07:49 AM
Last Post: danm1988
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 4,874 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 73,205 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 6,342 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 83,483 07-26-2024, 10:35 PM
