Mount eMMC after booting from SD card
You can, but it involved having the back plate off. There might be another way to do this, but what you'd want to do is :
Insert your bootable SD in the PBP.
Open the lid and lay they palm rest down on a surface, with the lid hanging off the edge. (recommended to avoid flexing/breaking plastics.)
With the emmc switch off, turn on the PBP.
When you see the power LED activate (uboot from the SD has started) turn the emmc switch to ON. You should have a few seconds from turning on to do this.
The PBP should now boot using the SD, with the emmc initialized by uboot. From there, let it boot up and do the maintenance you need.
RE: Mount eMMC after booting from SD card - by tophneal - 02-15-2020, 07:53 AM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,141 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 406 12-07-2023, 03:11 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,970 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 971 08-18-2023, 01:58 AM
Last Post: juliamenendez
  2TB SD Card Write Errors jiacovelli 3 1,045 06-02-2023, 06:13 PM
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,493 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,842 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 869 12-19-2022, 01:01 PM
Last Post: Besouro
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,104 10-10-2022, 06:22 AM
Last Post: maxjrh
  6/22 run of PBPs - is reimaging eMMC with new OS possible still? elitegamercody 29 11,444 10-04-2022, 07:55 PM
