Mobile Carriers in the United States
#34
(04-12-2020, 07:47 AM)laserbeamh Wrote:
(04-11-2020, 04:34 PM)dukla2000 Wrote:
(04-11-2020, 08:37 AM)laserbeamh Wrote: Also on Debian/Phosh
I know you asked about hotspotting in the other thread. I don't see how to set up a hotspot, but if you let me know where it is, I'll give it a shot!
Once you have mobile data running, goto Settings/WiFi and make sure WiFi is on. Then select the 3 dot settings icon at top between WiFi slider and X and select Hotspot.
(It will enable for about 30 seconds, if you are exceedingly quick you may even connect to it, then it will crash when modemmanager re-scans available WiFi networks. If so this is known issue already logged on GitLab )
I found it, but it's grayed out for me. I tried while connected to a network, after having forgotten all known networks, and with wifi off and nothing worked. I restarted the ModemManger service as well, but to no avail.
@neverused I'm sorry, I should have specified. I'm using a postpaid Verizon account. I'm not sure how much of a difference (if any) there is between pre- and postpaid from a service standpoint, but postpaid is nearly functional.
So Verizon had no qualms about registering your pinephone? I've heard they are particular about what devices they will allow in their network.
Mobile Carriers in the United States - by aren - 02-13-2020, 04:11 PM
RE: Mobile Carriers in the United States - by boggle - 04-13-2020, 02:07 PM
RE: Mobile Carriers in the United States - by RTP - 07-28-2020, 07:54 PM
  can I retrieve accidentally deleted voice mail with T mobile ? HLing 4 879 12-13-2023, 01:24 AM
Last Post: oldschool
  New Zealand network providers mobile data Linux2thabone 3 3,312 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 10 3,340 07-07-2023, 12:06 PM
Last Post: jovval
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 3,413 06-30-2023, 11:39 PM
Last Post: ionmich
  Current Situation With Setup and Carrier Activation With Tracfone Verizon T-Mobile pinephoneuser22 0 719 05-26-2023, 08:40 PM
Last Post: pinephoneuser22
  Cannot call at several mobile phones Gon 3 1,354 05-04-2023, 05:18 AM
Last Post: Gon
  MMS-Monitor: Help for carriers with dual APNs? treebeard 2 1,376 02-10-2023, 02:45 PM
Last Post: treebeard
  Phone carriers and the Speakout carrier bedtime 3 2,110 08-16-2022, 11:11 PM
Last Post: Oblivion2528
  compatible carriers the7thpoint 2 1,742 06-17-2022, 08:24 AM
Last Post: mikehenson
Lightbulb pinephone mobile dock jasmin763 2 1,738 06-06-2022, 09:06 AM
Last Post: 98cwitr
