Flash dhivael's SPI uboot (risky)
(02-07-2020, 02:04 PM)Wizzard Wrote: I flashed that, but it does not boot from NVMe neither SD card. I reflashed SD card with Armbian but still does not boot. What can be wrong? The screen is just blank with backlight and green LED is on.
I'm sorry that it didnt work for you. It is important to note this process is kinda risky since there are only 3 confirmed successful flashes this way. Can you tell me exactly what you did?
are you getting red then green dot or just green dot?
Worst case scenario you need to get back into maskrom then reflash pcm's uboot which you know works on your device. look at as400's guide in Pinebook Pro tutorials on how to do that. (https://forum.pine64.org/showthread.php?tid=9059) or simply erase the SPI completely and have uboot on emmc again or sd.
Flash dhivael's SPI uboot (risky) - by clover - 02-06-2020, 10:42 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 12:40 AM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 12:52 AM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 01:18 AM
RE: Flash dhivael's SPI uboot - by amiraeva - 02-07-2020, 09:42 AM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 02:04 PM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 02:42 PM
RE: Flash dhivael's SPI uboot - by User 15997 - 02-07-2020, 02:34 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 02:40 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 02:53 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 03:05 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 03:39 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 03:57 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 04:11 PM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 04:12 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 04:23 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-08-2020, 06:36 AM
RE: Flash dhivael's SPI uboot - by pinebro - 02-07-2020, 05:08 PM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 05:42 PM
RE: Flash dhivael's SPI uboot - by pinebro - 02-07-2020, 06:27 PM
RE: Flash dhivael's SPI uboot - by clover - 02-08-2020, 01:37 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 12:07 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-08-2020, 12:36 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 12:25 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 01:46 PM
Flash dhivael's SPI uboot (risky) - by Wizzard - 02-08-2020, 02:02 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 02:13 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-08-2020, 02:07 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-08-2020, 03:35 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-09-2020, 01:55 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-09-2020, 02:27 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-09-2020, 02:46 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 03-12-2020, 11:16 AM
RE: Flash dhivael's SPI uboot (risky) - by vrabac - 03-13-2020, 12:12 AM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 03-14-2020, 08:04 AM
  How to rewrite uboot to emmc pineitup 5 8,905 12-27-2020, 10:35 AM
Last Post: nightranger73
  Extracting a copy of SPI NOR flash contents using micro SD card and u-boot hmuller 0 2,742 09-21-2020, 11:24 AM
Last Post: hmuller
  Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card hmuller 0 3,461 09-21-2020, 10:02 AM
Last Post: hmuller
  In-Circuit Programming of SPI NOR Flash hmuller 13 18,386 09-13-2020, 01:20 PM
Last Post: hmuller
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 43 54,045 07-28-2020, 03:18 PM
Last Post: SamWilts
  How to boot Manjaro from NVME with uboot on eMMC as400 47 57,129 06-07-2020, 02:37 AM
Last Post: as400
  (almost) upstream uboot/atf User 15997 27 31,291 02-08-2020, 10:18 PM
Last Post: Natrox
  Widevine-flash on Chromium-SD Card mamboman777 3 6,488 01-20-2020, 04:00 PM
