Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native)
#92
Hey, I know I post in there a lot but I installed yquake2 this morning and the game won't run because it can't find a usable renderer :/
[idaho@pbpro-manjaro .yq2]$ quake2
Yamagi Quake II v7.42
Client build options:
+ OpenAL audio
Platform: Linux
Architecture: aarch64
Byte ordering: little endian
Added packfile '/home/idaho/.yq2//baseq2/pak0.pak' (3307 files).
Added packfile '/home/idaho/.yq2//baseq2/pak1.pak' (279 files).
Added packfile '/home/idaho/.yq2//baseq2/pak2.pak' (2 files).
Using '/home/idaho/.yq2//baseq2' for writing.
execing default.cfg
couldn't exec yq2.cfg
couldn't exec config.cfg
couldn't exec autoexec.cfg
Console initialized.
------- sound initialization -------
LoadLibrary(libopenal.so.1)
...opening OpenAL device:ok
...creating OpenAL context: ok
...making context current: ok
OpenAL settings:
AL_VENDOR: OpenAL Community
AL_RENDERER: OpenAL Soft
AL_VERSION: 1.1 ALSOFT 1.20.1
AL_EXTENSIONS: AL_EXT_ALAW AL_EXT_BFORMAT AL_EXT_DOUBLE AL_EXT_EXPONENT_DISTANCE AL_EXT_FLOAT32 AL_EXT_IMA4 AL_EXT_LINEAR_DISTANCE AL_EXT_MCFORMATS AL_EXT_MULAW AL_EXT_MULAW_BFORMAT AL_EXT_MULAW_MCFORMATS AL_EXT_OFFSET AL_EXT_source_distance_model AL_EXT_SOURCE_RADIUS AL_EXT_STEREO_ANGLES AL_LOKI_quadriphonic AL_SOFT_bformat_ex AL_SOFT_block_alignment AL_SOFT_deferred_updates AL_SOFT_direct_channels AL_SOFT_direct_channels_remix AL_SOFTX_effect_chain AL_SOFTX_events AL_SOFTX_filter_gain_ex AL_SOFT_gain_clamp_ex AL_SOFT_loop_points AL_SOFTX_map_buffer AL_SOFT_MSADPCM AL_SOFT_source_latency AL_SOFT_source_length AL_SOFT_source_resampler AL_SOFT_source_spatialize
Available OpenAL devices:
- ALSA Default
- rockchip,es8316-codec, ff890000.i2s-ES8316 HiFi ES8316 HiFi-0 (CARD=rockchipes8316c,DEV=0)
Current OpenAL device:
- OpenAL Soft
Number of OpenAL sources: 31
Sound sampling rate: 0
libGL error: MESA-LOADER: failed to open rockchip (search paths /usr/pkg/lib/dri)
libGL error: failed to load driver: rockchip
SDL version is: 2.0.10
SDL video driver is "x11".
SDL didplay modes:
- Mode  0: 1920x1080@60
----- refresher initialization -----
LoadLibrary(ref_gl1.so)
Sys_LoadLibrary failed: /usr/pkg/libexec/ref_gl1.so: cannot open shared object file: No such file or directory
Loading /usr/pkg/libexec/ref_gl1.so as renderer lib failed!Retrying with soft...
LoadLibrary(ref_soft.so)
Sys_LoadLibrary failed: /usr/pkg/libexec/ref_soft.so: cannot open shared object file: No such file or directory
Loading /usr/pkg/libexec/ref_soft.so as renderer lib failed!Shutting down OpenAL.
Cmd_RemoveCommand: force_centerview not added
Cmd_RemoveCommand: +mlook not added
Cmd_RemoveCommand: -mlook not added
Shutting down input.
recursive shutdown
Error: No usable renderer found!
Here is the content of "/usr/pkg/lib/dri":
[idaho@pbpro-manjaro dri]$ ls
kms_swrast_dri.so  nouveau_drv_video.so  r200_dri.so  r600_drv_video.so  radeonsi_drv_video.so
lima_dri.so        nouveau_vieux_dri.so  r300_dri.so  radeon_dri.so      swrast_dri.so
nouveau_dri.so     panfrost_dri.so       r600_dri.so  radeonsi_dri.so    vc4_dri.so
Is it because I switched to the panfrost driver and that it can't use it? Huh
Edit: I managed to get the game running by copying ref_gl1.so ref_gl3.so and ref_soft.so from the "/usr/pkg/share/yquake2" directory to "/usr/pkg/libexec" and it runs but the game is quite laggy at 1080p, is this normal behavior? I suspect there's a problem with which driver the game should be using (I also tried copying "rockchip_dri.so" from "usr/lib/dri" to "usr/pkg/lib/dri" and the game just gives me a black screen and steels the mouse focus when I try to switch windows...
Edit2: I've put the rendering options to software in the game and there's no lagging anymore, the opengl options make things laggy, so I guessmy driver issue suspicions were right, do you think the p I blem is on my end or with the package??
RE: Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) - by Idaho - 04-03-2020, 02:30 AM
  Pinebook Pro Initial Impressions kunger 443 598,847 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,385 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 463 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 344 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 334 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 267 02-14-2024, 09:01 AM
  Manjaro versions bad and good gilwood 0 301 02-12-2024, 05:03 PM
Last Post: gilwood
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 747 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 822 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,813 12-17-2023, 09:29 PM
Last Post: insideau786
