Partitioning MicroSD card for boot/storage
(05-01-2016, 04:34 AM)Leoncito81 Wrote: Burn the image without partitions. Boot the system and use the package manager to install gparted. You can then add or change your partition with a gui interface. That will work for most any Linux install. Not sure about Remix.
My next board is probably going to be a linux setup, so that will help when I get around to that project. Thank you!
RE: Partitioning MicroSD card for boot/storage - by KillrKowalski - 05-01-2016, 06:30 PM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 67 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,177 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,613 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,584 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,705 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,105 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,252 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,160 10-18-2020, 01:41 PM
Last Post: toiny
  micro sd card won't insert Samuel Venable 2 4,483 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,385 06-19-2020, 06:58 AM
