An interesting display problem has developed
(11-08-2019, 05:56 PM)Watercourse Wrote: Suddenly...
When i move any window on the screen i get a 3x3 grid that redraws itself sloooowly several times across the arc of the movement, and when it settles down the content of the window can be used again. I was playing with redshift when this began (it has has since been removed), and the only other change today was an apt upgrade or apt dist-upgrade something or other.
Is there a logfile for apt grades? There must be.
Assuming i can find the upgraded, i imagine i could roll it back but i don't know how to do either of those steps.
Sorry for the newbie helplessness, but my PBP is not really usable like this. Undecided
Anyone want to share some expertise?
Adding: Default Debian/MATE up-to-date
A 3x3 grid sounds like an outline window drag. I don't have experience with MATE, but Gnome2 had a low resources mode that would enable that.
I could not find anything like this in the settings, so I installed dconf-editor. dconf-editor is like windows regedit.exe. Open it and navigate to "/org/mate/marco/general/". Look for "reduced-resources", it should be set to false. I don't see any outline window mode settings, if you see anything like that it should be set to false
RE: An interesting display problem has developed - by SatnSpwn - 11-17-2019, 09:03 PM
  Manjaro network problem late 2023 acruhl 1 382 01-19-2024, 11:32 PM
  Sleep and external display - Are there any options? chris88233 7 1,826 09-04-2023, 09:03 PM
  Help please, problem with xen domU guest on rockpro64 pine64 v2.1 mrc1965 1 1,204 08-21-2023, 09:05 PM
Last Post: vanessadonald
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,299 12-09-2022, 12:43 PM
Last Post: as365n4
  upgrade problem trying4firstbass 1 820 11-28-2022, 01:44 AM
  u-boot flashing problem dex357 2 2,475 11-27-2021, 04:13 AM
Last Post: dex357
  Garbled display with kernels 5.15 and 5.14 schwarzwieweiss 4 3,242 11-07-2021, 06:30 AM
Last Post: schwarzwieweiss
Question External display doesn't work in TwisterOS (Armbian) TDC_PBP 0 1,565 08-21-2021, 02:46 PM
Last Post: TDC_PBP
  Manjaro Dim Display (Brightness 40%) After Every System Reboot runlinux.run 2 3,152 02-15-2021, 07:04 PM
Last Post: MtnSk8
  External display stopped working, "dpcd read failed: -22" in dmesg zackw 3 5,446 05-01-2020, 03:14 AM
Last Post: Valinor
