ROCKPRO64 with 10GbE NICs
Additional SMB info that I always post:
Don't forget "min protocol = SMB2" in your Samba config (and restart smbd), because otherwise it allows for SMB1, and Windows could accidentally select SMB1 instead of SMB2 unless you ALSO configured your Windows client specifically NOT to use SMB1.
On the Windows side: https://support.microsoft.com/en-us/help...indows-and
It's best to specify on both ends that you want SMB2 so there's no way it can mess up.
[ If you've already mitigated Windows for 'wannacry', then you should have SMB1 off and SMB2 on already. ]
( In the future, we'll want SMB3, but Samba's SMB3 support is limited. You could try 3 if you are able, but I personally haven't tested Samba's SMB3 since I can't exceed SMB2 performance. )
ROCKPRO64 with 10GbE NICs - by H.HSEL - 12-17-2018, 06:44 AM
RE: ROCKPRO64 with 10GbE NICs - by xalius - 12-17-2018, 02:41 PM
RE: ROCKPRO64 with 10GbE NICs - by fosf0r - 12-17-2018, 03:52 PM
RE: ROCKPRO64 with 10GbE NICs - by H.HSEL - 12-18-2018, 05:35 AM
RE: ROCKPRO64 with 10GbE NICs - by ddimension - 12-18-2018, 04:24 PM
RE: ROCKPRO64 with 10GbE NICs - by ddimension - 02-24-2019, 03:35 AM
RE: ROCKPRO64 with 10GbE NICs - by ddimension - 03-03-2019, 02:02 AM
RE: ROCKPRO64 with 10GbE NICs - by H.HSEL - 12-19-2018, 06:45 AM
RE: ROCKPRO64 with 10GbE NICs - by gokuz - 12-20-2018, 03:30 AM
RE: ROCKPRO64 with 10GbE NICs - by Ryan - 01-28-2019, 09:07 PM
RE: ROCKPRO64 with 10GbE NICs - by Ryan - 01-31-2019, 09:52 PM
RE: ROCKPRO64 with 10GbE NICs - by igorp - 08-14-2019, 12:09 AM
RE: ROCKPRO64 with 10GbE NICs - by igorp - 08-14-2019, 01:37 PM
  Installing Wifi drive for the RockPro64 John45595 0 313 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 764 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 685 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,265 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 894 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,331 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,829 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,661 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,023 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,805 10-21-2022, 07:44 AM
Last Post: rapier1
