(ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release
#48
(04-09-2016, 05:35 PM)longsleep Wrote:
(04-09-2016, 12:36 PM)androsch Wrote: As far as i understand the process, this seems to be an issue regarding DMA and network with the 2GB ram model, right?
No. The Ethernet driver has been fixed to work with memory lagerer 1GB and the fix was released with kernel 3.10.65-4-pine64-longsleep-16 - if you can confirm that the same cable and switch Port work with 1000M for another non Pine device your Pine is either defect or needs other Timings in the device tree. Feel free to Experiment with the Timings at https://github.com/longsleep/build-pine6....dts#L2562
Had already contact to Lenny.raposo regarding network speed. Interesting thing is with iperf3 and Pine64 at the gigabit port as client i have also about 420MBits, only with Pine64 on gigabit as server the speed drops down to 4-5MBits and e.g. internet speed reading towards the Pine is also dropping nearly to zero (less than 20kbytes).
Error is reproducable, e.g. switching the port on the router between 100MBit and gigabit -> Pine speed drops resp. goes up again.
Sorry, but I'm no developer at all, so it's interesting, there are so many timing and setup parameters to see in your link, but I really don't know how to handle this Sad
For me at the moment it's fine working with just 100MBit, i just wanted to give feedback, there still are issues with the 2GB model and gigabit lan and hope my feedback gives hints to sort this out.....
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
RE: Debian Image In The Works - by umiddelb - 03-30-2016, 01:58 AM
RE: Debian Image In The Works - by tllim - 03-30-2016, 02:08 AM
RE: Debian Image In The Works - by longsleep - 03-30-2016, 11:50 AM
RE: Debian Image In The Works - by Bargepole - 04-02-2016, 05:57 AM
RE: Debian Image In The Works - by Ghost - 04-03-2016, 07:55 PM
RE: Debian Image In The Works - by Bargepole - 04-04-2016, 12:35 AM
RE: Debian Image In The Works - by tnecniv102 - 05-01-2016, 09:36 AM
RE: Debian Image In The Works - by tkaiser - 05-01-2016, 10:27 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 02:35 AM
RE: Debian Image In The Works - by merriam - 04-05-2016, 09:26 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 11:57 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 11:18 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 01:13 PM
RE: Debian Image In The Works - by androsch - 04-09-2016, 12:36 PM
RE: Debian Image In The Works - by longsleep - 04-09-2016, 05:35 PM
RE: Debian Image In The Works - by androsch - 04-09-2016, 05:51 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 02:22 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 03:03 PM
RE: Debian Image In The Works - by rahlquist - 04-07-2016, 05:30 AM
RE: Debian Image In The Works - by rahlquist - 04-08-2016, 06:13 AM
Success with this... - by cbbrowne - 04-13-2016, 10:16 AM
issue with 2 ethernet lines - by dkryder - 07-03-2016, 03:31 AM
  Debian installer on Pine A64+ but no hdmi mrwick 1 5,012 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 13,066 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 3,012 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 10,358 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 123,416 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 4,868 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 4,306 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 6,442 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 13,393 03-29-2019, 02:00 AM
Last Post: desai_amogh
  how to set kernel parameter 'fsck.mode=force' marcelser 6 12,325 05-09-2018, 09:07 PM
Last Post: pfeerick
Users browsing this thread: 11 Guest(s)
