(ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release
#27
(04-08-2016, 07:20 AM)lenny.raposo Wrote: The images are not the factor here as they work for others. There can be 4 possibilities here.
1) Faulty SD Card(s).
2) Faulty PC MMC Drive.
Try an Android/Remix OS image and see if it is yielding the same results in terms of FS/partition corruption (try multiple cards). Remember to safely eject the cards when using windows (right click on drive > Eject in Explorer). For good measure wait a few minutes after the write to disk is completed.
I wanted to ask if you have resized the RootFS after burning to disk?
If not then when you first login into your pine (linux image)
run
sudo -i
/usr/local/sbin/resize-rootfs.sh
That should resize the rootfs partition.
Let me know if you have any issues with corruption after doing that
I am starting to think its my card reader. I have grabbed another microsd from a different device (didnt want to use this one as it was already in use for something else). Before I installed your image I wanted to backup what I had on it. So I was using win32 Disk Imager to do just that, when in the middle of reading it, windows reported an error and win32 imager did as well. So isntead of using just the microsd card slot on my reader I have moved the microsd into a microsd to sdcard adapter and I am trying that. Will let you know.
RE: Debian Image In The Works - by umiddelb - 03-30-2016, 01:58 AM
RE: Debian Image In The Works - by tllim - 03-30-2016, 02:08 AM
RE: Debian Image In The Works - by longsleep - 03-30-2016, 11:50 AM
RE: Debian Image In The Works - by Bargepole - 04-02-2016, 05:57 AM
RE: Debian Image In The Works - by Ghost - 04-03-2016, 07:55 PM
RE: Debian Image In The Works - by Bargepole - 04-04-2016, 12:35 AM
RE: Debian Image In The Works - by tnecniv102 - 05-01-2016, 09:36 AM
RE: Debian Image In The Works - by tkaiser - 05-01-2016, 10:27 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 02:35 AM
RE: Debian Image In The Works - by merriam - 04-05-2016, 09:26 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 11:57 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 11:18 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 01:13 PM
RE: Debian Image In The Works - by androsch - 04-09-2016, 12:36 PM
RE: Debian Image In The Works - by longsleep - 04-09-2016, 05:35 PM
RE: Debian Image In The Works - by androsch - 04-09-2016, 05:51 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 02:22 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 03:03 PM
RE: Debian Image In The Works - by rahlquist - 04-07-2016, 05:30 AM
RE: Debian Image In The Works - by rahlquist - 04-08-2016, 06:13 AM
RE: Debian Jessie Images (3.10.65 BSP Kernel) - by rahlquist - 04-08-2016, 07:44 AM
Success with this... - by cbbrowne - 04-13-2016, 10:16 AM
issue with 2 ethernet lines - by dkryder - 07-03-2016, 03:31 AM
  Debian installer on Pine A64+ but no hdmi mrwick 1 4,964 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 12,959 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 2,991 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 10,279 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 122,681 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 4,828 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 4,272 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 6,383 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 13,289 03-29-2019, 02:00 AM
Last Post: desai_amogh
  how to set kernel parameter 'fsck.mode=force' marcelser 6 12,198 05-09-2018, 09:07 PM
Last Post: pfeerick
