(ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release
Hello. I got my Pine finally Smile but without ABS Case Sad.
At start I tried images suggested by PINE but no luck. They stuck at the boot after couple of minutes.
Then I tried Jessie's image. MARVELOUS. Fast and accurate.
I managed to log in in less than minute. My USB HUB work great with this image.
I have couple of Q's here:
1. I just can't find Jessie's explanation, something about expanding space on Sd card or similar. Looks like his first post is modified since my last log in here. Is this still valid operation to be done after booting up image or it is already automated ?
2. Regarding Iceweasel as a primary browser. It crashes (close) twice since I ran image, Is it due to lack of memory (at this moment I am using Maxell 8GB card, just for testing) or it is a known bug ?
3. Received push button, should be soldered on top of board, where it says POWER (next to RESET) or should I make melting of closed holes and put through board connectors and solder them from bottom side ? I must mention that these holes are already soldered.
I am fully supporting Jessie and his work.
Now I am going to test Android images but I think I will stuck at the same place as before with other images Smile
Regards,
RE: Debian Image In The Works - by umiddelb - 03-30-2016, 01:58 AM
RE: Debian Image In The Works - by tllim - 03-30-2016, 02:08 AM
RE: Debian Image In The Works - by longsleep - 03-30-2016, 11:50 AM
RE: Debian Image In The Works - by Bargepole - 04-02-2016, 05:57 AM
RE: Debian Image In The Works - by Ghost - 04-03-2016, 07:55 PM
RE: Debian Image In The Works - by Bargepole - 04-04-2016, 12:35 AM
RE: Debian Image In The Works - by tnecniv102 - 05-01-2016, 09:36 AM
RE: Debian Image In The Works - by tkaiser - 05-01-2016, 10:27 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 02:35 AM
RE: Debian Image In The Works - by merriam - 04-05-2016, 09:26 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 11:57 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 11:18 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 01:13 PM
RE: Debian Image In The Works - by androsch - 04-09-2016, 12:36 PM
RE: Debian Image In The Works - by longsleep - 04-09-2016, 05:35 PM
RE: Debian Image In The Works - by androsch - 04-09-2016, 05:51 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 02:22 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 03:03 PM
RE: Debian Image In The Works - by rahlquist - 04-07-2016, 05:30 AM
RE: Debian Image In The Works - by rahlquist - 04-08-2016, 06:13 AM
Success with this... - by cbbrowne - 04-13-2016, 10:16 AM
RE: Debian Jessie Images (3.10.65 BSP Kernel) - by janeku - 06-27-2016, 02:02 PM
issue with 2 ethernet lines - by dkryder - 07-03-2016, 03:31 AM
  Debian installer on Pine A64+ but no hdmi mrwick 1 4,972 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 12,986 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 2,994 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 10,298 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 122,708 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 4,838 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 4,282 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 6,393 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 13,314 03-29-2019, 02:00 AM
Last Post: desai_amogh
  how to set kernel parameter 'fsck.mode=force' marcelser 6 12,214 05-09-2018, 09:07 PM
Last Post: pfeerick
