Problems making the boot sd card (android)
(02-03-2016, 02:17 PM)Tarjei85 Wrote:
(02-03-2016, 02:06 PM)SkairkrohBule Wrote:
(02-03-2016, 01:00 PM)Tarjei85 Wrote: Thank you. I didnt try disconnecting the card and then reconnecting it. Will try when I get back from work. If that doesnt work I will try your approach Nilocsemliw.
Thank you for the quick response. Will keep you posted.
I had the same issue, after burning the OS image to the micro sd card, Windows was still saying the card was empty. However, if I put it into a computer running Linux (Ubuntu), it recognised the card straight away (there were 3 partitions, can't recall what they were called, but there was stuff on the card).
That sounds good. I dont currently have a computer running Linux, but I will try all the suggested sollutions and hopefully everything is ok.
Linux and Android using EXT4 file system and not natively recognized by Windows OS.
RE: Problems making the boot sd card (android) - by tllim - 02-03-2016, 06:20 PM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 76 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,183 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,619 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,587 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,708 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,118 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,256 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,161 10-18-2020, 01:41 PM
Last Post: toiny
  micro sd card won't insert Samuel Venable 2 4,487 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,393 06-19-2020, 06:58 AM
