Problems making the boot sd card (android)
(02-03-2016, 12:32 PM)Tarjei85 Wrote: Hi I have some problems making the android OS "work" for my Pine (havent recieved the Pine yet but am preparing).
After using the PhenixCard software and getting the progressbar to the max and the "done" notification I checked the sd-card but there is nothing on it. Still 119 of 119Gb free space (Im using a 128Gb card).
Have I misundstood anything? Does the phoenixcard software only make the sdcard bootable or is it supposed to copy the android image to the card as well.
The same thing was happening to me but after ejecting and inserting SD Card again to PC,
If windows wants to format your SD Card, everything is OK image is installed.
RE: Problems making the boot sd card (android) - by Hahaburger - 02-03-2016, 12:54 PM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 194 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,261 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,698 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,601 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,724 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,168 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,282 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,177 10-18-2020, 01:41 PM
Last Post: toiny
  micro sd card won't insert Samuel Venable 2 4,522 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,427 06-19-2020, 06:58 AM
