what is the magic dd incantation to copy the system from the sd card to the emmc?
OK, I see you said you have usb -> emmc adapter
make an image of present emmc, maybe on usb key on pbp
dd if=/dev/emmc of=/mnt/sda/emmc.img bs=1M status=progress
(if you don't have a big enough key, pipeline thru gzip,, as so
dd if=dev/emmc bs=1M|gzip >someplace, usb key,,emmc.gz)
Then, with adapter you easily restore any screw-up,
that is I am assuming you have another computer?
Then do a install (of armbian) on emmc,,,DO NOT shut it off
until you ALSO install pcm uboot to emmc (as last step before reboot)
See, with a partition copy install, fstab, boot.scr and probably the initrd need to be adjusted
Because those are all set for the SD
BTW,,,pbp reboot is flakey, do a shut off, reboot often hangs
RE: what is the magic dd incantation to copy the system from the sd card to the emmc? - by wdt - 08-10-2022, 01:06 PM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 345 03-01-2024, 06:46 PM
Last Post: Puckla
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,197 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 427 12-07-2023, 03:11 PM
  Fedora 36 -> 37 upgrade kills system tydeman 0 464 10-28-2023, 09:53 AM
Last Post: tydeman
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,003 08-21-2023, 09:08 PM
Last Post: vanessadonald
  2TB SD Card Write Errors jiacovelli 3 1,084 06-02-2023, 06:13 PM
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,538 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,931 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 880 12-19-2022, 01:01 PM
Last Post: Besouro
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,125 10-10-2022, 06:22 AM
Last Post: maxjrh
