"Emergency" terminal on pinephone (with default setup)
Due to the rate of development the 'default' OS that is delivered on the phone will be out of date. It's usually best to replace it with an up to date version when the phone arrives. See the wiki for instructions.
There isn't a direct 'emergency mode' equivalent, but there are a few options you can use:
* boot from uSD instead of the internal eMMC and use the OS on the uSD for recovery
* boot with a serial cable in the headphone socket - this gives you a serial terminal for the bootloader, and subsequent OS.
* boot to 'USB mass storage' mode with either tow-boot or JumpDrive and use a desktop linux to mount the internal drive and do any repairs
* if you have sshd set up on the phone, and the phone auto-connects to the network, you can ssh in even with a blank screen and do repairs.
There are probably more I haven't thought of.
If you use the p-boot bootloader you can probably configure a recovery boot option too, but without an on-screen keyboard you'll need an external one as you say. I often use ssh when more than a little text input is needed, and have used it for recovery in blank-screen situations such as when there was a bug with the auto-brightness that turned off the backlight.
RE: "Emergency" terminal on pinephone (with default setup) - by wibble - 04-30-2022, 01:53 AM
  link for supported pinephone os manjharo et all penguins_rule 3 313 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 491 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 1,870 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 2,626 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 7,690 02-04-2023, 08:35 PM
Last Post: Westslope
  nextcloud setup mruser1 2 1,757 12-05-2022, 03:22 AM
Last Post: alaraajavamma
  Pinephone craches after each call neithan76 2 1,652 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,922 07-28-2022, 12:40 PM
Last Post: johaennessen
  Can't install software via Discover or Terminal Kimberley van Buyten 2 1,604 06-10-2022, 02:13 AM
Last Post: shulamy
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,124 05-09-2022, 08:29 AM
Last Post: ragreenburg
