Guide to Suitable Phone State
Sorry your SD card slot is broken. As a tip for the future, you don't have to remove the SD card from the phone to write it.
If you want you should be able to put the phone bootloader into USB Mass Storage mode. See the bottom of https://tow-boot.org/devices/pine64-pinephonePro.html - if you have tow-boot on your SPI flash, holding volume up will make the LED turn "blue" instead of "aqua".
You should then be able to use the directions in Step 3 to install directly to flash.
I have no idea if MMS works. Plain SMS does. If your SIM slot is broken you're not going to be using either with the phone's built-in modem.
Guide to Suitable Phone State - by Borealid - 04-16-2022, 10:02 PM
RE: Guide to Suitable Phone State - by lat - 04-27-2022, 07:38 AM
RE: Guide to Suitable Phone State - by Borealid - 04-27-2022, 02:53 PM
RE: Guide to Suitable Phone State - by tckosvic - 04-28-2022, 11:01 AM
RE: Guide to Suitable Phone State - by Borealid - 04-28-2022, 04:10 PM
RE: Guide to Suitable Phone State - by tckosvic - 04-29-2022, 10:23 AM
RE: Guide to Suitable Phone State - by Borealid - 04-29-2022, 10:34 AM
RE: Guide to Suitable Phone State - by tckosvic - 04-29-2022, 12:17 PM
RE: Guide to Suitable Phone State - by fxc - 04-30-2022, 08:02 AM
RE: Guide to Suitable Phone State - by Borealid - 04-29-2022, 06:57 PM
RE: Guide to Suitable Phone State - by tckosvic - 04-30-2022, 11:46 AM
RE: Guide to Suitable Phone State - by jakfish - 05-04-2022, 08:25 PM
RE: Guide to Suitable Phone State - by cj-mcquack - 05-05-2022, 01:30 PM
RE: Guide to Suitable Phone State - by Dragonborn - 05-05-2022, 04:03 PM
RE: Guide to Suitable Phone State - by wibble - 05-06-2022, 04:42 AM
RE: Guide to Suitable Phone State - by Dragonborn - 05-06-2022, 03:17 PM
RE: Guide to Suitable Phone State - by wibble - 05-07-2022, 05:26 AM
RE: Guide to Suitable Phone State - by mburns - 05-08-2022, 08:46 AM
RE: Guide to Suitable Phone State - by robocone - 09-18-2023, 07:00 AM
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 42 12,518 12-26-2023, 02:14 PM
Last Post: apink
  Phone Attitude(Device orientation) lurkadillian 2 1,053 06-22-2023, 08:12 PM
Last Post: lurkadillian
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 1,783 02-18-2023, 06:14 PM
Last Post: fxc
  [Mobian] No return from locked phone arno_nuehm 1 1,030 02-06-2023, 07:57 AM
Last Post: arno_nuehm
  Phone shuts down unexpectedly Hobgoblin 3 1,614 12-20-2022, 01:11 PM
Last Post: Fish
  Sound completely gone with Mobian in Phone Call configuration EwigeBlumenkraft 2 1,774 11-11-2022, 09:18 PM
Last Post: apink
  PinePhone Pro Manjaro Plasma Mobile Beta 13 & No Audio with Phone Calls X0X0X0X0X0 0 1,099 11-02-2022, 02:09 PM
Last Post: X0X0X0X0X0
  Outgoing audio in phone calls gone linuxfreedom 6 3,346 10-25-2022, 08:40 PM
Last Post: apink
  Phone wont turn on with any SD Card inserted Ausfaller 3 2,420 07-21-2022, 10:20 AM
Last Post: Ausfaller
  PPP Phone rings with constant vibrate - turn off vibrate henrythemouse 0 845 05-16-2022, 03:59 PM
Last Post: henrythemouse
