Pinephone is dead (sort of)
(12-28-2021, 07:28 AM)moodroid Wrote: If you think that your anti virus software is interfering (not heard it mentioned before), then you could just temporarily disable it and try again?
If it still doesn't work, then there's probably a problem with the compressed image that you're trying, e.g. bad build or it didn't download properly, so might be worth downloading a different one and trying that.
Thank you for replying.
I've tried Windows 11 again, but there is no Jumpdrive emmc to flash to! That's what I'm so worried about. I use Balena Etcher.
Chris
Pinephone is dead (sort of) - by thorensjubilee - 12-28-2021, 05:40 AM
RE: Pinephone is dead (sort of) - by moodroid - 12-28-2021, 07:28 AM
RE: Pinephone is dead (sort of) - by thorensjubilee - 12-28-2021, 07:34 AM
RE: Pinephone is dead (sort of) - by moodroid - 12-28-2021, 08:14 AM
RE: Pinephone is dead (sort of) - by moodroid - 12-29-2021, 06:18 AM
RE: Pinephone is dead (sort of) - by moodroid - 12-29-2021, 07:46 AM
RE: Pinephone is dead (sort of) - by moodroid - 12-31-2021, 04:44 AM
RE: Pinephone is dead (sort of) - by moodroid - 12-31-2021, 07:10 AM
RE: Pinephone is dead (sort of) - by wibble - 12-31-2021, 11:49 AM
RE: Pinephone is dead (sort of) - by wibble - 12-31-2021, 01:02 PM
RE: Pinephone is dead (sort of) - by moodroid - 01-01-2022, 08:10 AM
  PinePhone - boot from microSD laserpyramid 9 781 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 401 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 267 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,451 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,901 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 650 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,474 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 531 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,772 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,059 12-04-2023, 02:14 AM
Last Post: Peter Gamma
