(06-22-2016, 04:11 AM)pingyingtu Wrote: Hi,
1) I try to use adb via usb in linux(mint), but do not work.
So, I think the usb just a power line, can't transfer data.
2) I use adb connect ip, PineA64 can to be connected.
But sometime it disconnect. I don't why.
3) I start a new apk in Android Studio, empty apk,
I can't debug the apk.
4) adb shell not work
5) I'm so sad.
Hi.Which USB are you using? The micro-USB is only power. The other two are connected to individual host controllers, so you have to look into that. I am no Android developer, but I know that for bootloader over the USB, a special A to A cable is used. This will probably only work for the OTG controller since it can switch directions... using an A to A cable the wrong way can damage your devices, so proceed with caution.
Come have a chat in the Pine IRC channel >>
