Android Pine A64 driver
I got a Pine A64 2G device,
I want to write some apks on it.
1) When I connet the device to Windwos 7 through USB,
adb do not regcognize Pine A64 device.
I think I need the Windows 7 driver for this device.
Is there a drivers?
2) I want to use PI 2 pin on Android to control some Iot devices(ex SPI / I2C).
I will try to port some raspberry pi program to Android on Pine A64.
(Qt is support raspberry pi and Android, this is a good way for Iot)
Is Android version support PI 2 pin?
I'm not sure as I haven't tried it but did you make sure ADB debugging was enabled in android system settings?
Hi Nagmier,
ADB debugging was enabled in Android system settings,
I have turn it on at developer options.
1) I try to use adb via usb in linux(mint), but do not work.
So, I think the usb just a power line, can't transfer data.
2) I use adb connect ip, PineA64 can to be connected.
But sometime it disconnect. I don't why.
3) I start a new apk in Android Studio, empty apk,
I can't debug the apk.
4) adb shell not work
5) I'm so sad.
(06-22-2016, 04:11 AM)pingyingtu Wrote: Hi,
5) I'm so sad.
Hi.Which USB are you using? The micro-USB is only power. The other two are connected to individual host controllers, so you have to look into that. I am no Android developer, but I know that for bootloader over the USB, a special A to A cable is used. This will probably only work for the OTG controller since it can switch directions... using an A to A cable the wrong way can damage your devices, so proceed with caution.
Yes, I use micro-usb.
I will try another type-A usb.
(06-22-2016, 04:52 AM)pingyingtu Wrote: >Which USB are you using? The micro-USB is only power.
The OTG port is on the upper USB Type A port and you need a adapter.
Hello Pingyingtu
Were you able to connect to the Pine64 using type-A usb port ? What Driver did you select in Android SDK Manager ? I have order type A to type A cable from ebay. Just waiting for it to arrive. Cannot wait to use a dedicated board for app debugging. Smile
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,678 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 609,198 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,322 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,109 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,736 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,324 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,607 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,777 07-15-2019, 08:29 PM
  Bliss OS (PINE A64(+)) pineadmin 4 18,316 06-07-2019, 09:01 PM
Last Post: nukedawg
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 410,173 03-12-2019, 04:53 PM
Last Post: neosapien
