PBP won't boot from eMMC or SD card: a saga
Most Linux distributions issue a reboot when you press ctrl-alt-del on the text console.
Regarding whether this a u-boot problem: No, if the OS is booting u-boot is fine (at least to some degree). However, if the OS is not working and you want to reinstall it or switch to another, you need either an u-boot version that priorizes sd over eMMC or one of the described approaches for booting from sd.
RE: PBP won't boot from eMMC or SD card: a saga - by kuleszdl - 01-12-2021, 10:29 AM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,143 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,220 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 406 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,232 11-23-2023, 07:37 AM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,972 08-21-2023, 09:08 PM
Last Post: vanessadonald
  2TB SD Card Write Errors jiacovelli 3 1,049 06-02-2023, 06:13 PM
  Emergency Mode Boot Hotkey? jiacovelli 20 4,434 06-02-2023, 01:32 PM
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,498 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,848 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 869 12-19-2022, 01:01 PM
Last Post: Besouro
