Screws on bottom case coming loose
(01-10-2021, 10:19 AM)KC9UDX Wrote: Or the nut broke loose.  I've had mine apart many times now but I don't recall what the nut looks like.  Also there have been reports that the screws are very soft, it could be that the screw is stripped.
I don't know why you need a whole bottom case to replace the foot, but it does seem that you need the screw repair kit.
The factory used blue threadlocker which is probably equivalent to Loctite Blue 242.  It seemed a little weaker to me.  But I could be wrong.  Certainly don't use any threadlocker that's red.
FWIW you can buy a whole set of rubber feet for around $2 at your local hardware store.
The new bottom case for my Pinebook Pro arrived today. I have managed to fit it but unscrewing the old bottom case I noticed that none of the screws felt tight. I couldn't see any obvious damage to the screws, so I was thinking of applying Loctite 243 blue thread lock to all of the screws (I don't seem to be able to find 242 here in France).
I see that normally one applies a drop of Loctite to each screw, but since the screws are so small, I'm tempted to put a drop in each hole, then put the bottom case back in place and screwing the screws back in.
Would this be the right way to proceed?
Thx.
Would this be right?
RE: Screws on bottom case coming loose - by quadrantids - 01-19-2021, 12:15 PM
Question High Pitch Noise Coming From Pinebook Pro User 11436 60 83,916 11-16-2022, 02:51 PM
Last Post: kebab
  alarming sound coming from pinebook pro jazzhands 2 1,663 08-21-2022, 02:34 PM
Last Post: foobar
  Suggested software for use case ehcorn 4 2,096 08-17-2022, 04:06 PM
Last Post: TRS-80
  Pinebook Pro Case models sundog 2 2,869 11-05-2020, 09:31 AM
Last Post: sundog
  Minor case damage with gentle use. (Is anyone else seeing this?) hikaricore 31 35,526 10-26-2020, 10:19 PM
Last Post: hikaricore
  Screws and Spacers belfastraven 11 12,802 10-13-2020, 09:57 AM
Last Post: feoh
  Got a case for my Pinebook Pro GhostDragon 3 4,269 09-24-2020, 07:24 PM
Last Post: bastafari
  Case defect (crack) bigCamel 25 24,971 08-18-2020, 03:41 PM
Last Post: bigCamel
  Case upgrade for my PBP robt 2 3,878 08-08-2020, 04:35 PM
Last Post: Damon
  Missing Screws missingchip 2 4,150 06-06-2020, 04:08 PM
Last Post: missingchip
