PinePhone OS & Malfunction
(12-12-2020, 02:43 AM)tommaso Wrote: Please, have you any way to install mobian? I'm used to install Debian from ISO CD, for this I use a sofware to make iso DVD and than I boot from that. How can I do this with the phone from USB pen? Is it possible?
You need to flash a system image to sdcard, or you need to flash jumpdrive to a sdcard and then the internal memory will show up as a storage device on USB.
https://mobian-project.org/
PinePhone OS & Malfunction - by tommaso - 11-21-2020, 03:00 AM
RE: PinePhone OS & Malfunction - by tommaso - 11-23-2020, 07:16 AM
RE: PinePhone OS & Malfunction - by ryo - 11-23-2020, 04:55 PM
RE: PinePhone OS & Malfunction - by tommaso - 11-25-2020, 08:46 AM
RE: PinePhone OS & Malfunction - by ryo - 11-25-2020, 04:03 PM
RE: PinePhone OS & Malfunction - by ryo - 11-21-2020, 08:25 AM
RE: PinePhone OS & Malfunction - by hiimtye - 11-21-2020, 05:05 PM
RE: PinePhone OS & Malfunction - by tommaso - 11-23-2020, 01:53 AM
RE: PinePhone OS & Malfunction - by ryo - 11-23-2020, 04:47 AM
RE: PinePhone OS & Malfunction - by tommaso - 12-12-2020, 02:43 AM
RE: PinePhone OS & Malfunction - by evilbunny - 12-12-2020, 05:25 AM
  systemic issue pinephone penguins_rule 3 469 04-02-2024, 11:52 AM
  link for supported pinephone os manjharo et all penguins_rule 2 270 03-19-2024, 10:36 AM
Last Post: penguins_rule
  new PinePhone upgrade issue WhiteHexagon 5 1,847 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 2,588 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 7,644 02-04-2023, 08:35 PM
Last Post: Westslope
  Pinephone craches after each call neithan76 2 1,645 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,792 07-28-2022, 12:40 PM
Last Post: johaennessen
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,106 05-09-2022, 08:29 AM
Last Post: ragreenburg
  "Emergency" terminal on pinephone (with default setup) altulke 5 2,731 05-03-2022, 12:42 PM
Last Post: altulke
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 1,914 04-07-2022, 06:02 AM
Last Post: danimations
