PinePhone OS & Malfunction
(11-25-2020, 08:46 AM)tommaso Wrote: Thanks indeed!
Have you got any idea in which way it would be possible to make so that contacts and dial software work together? Are there any other software for dialing and contacts? More precisely: Once dialed or received a phone number it is not possible to save in in the contacts and when you save a contact or when you find a contact in the contact application it is impossible to start directly a phone call. This is really uncomfortable especially if you are not sitting at a desk.
Thanks again, Best Regards
I didn't get a phone independent USIM yet, neither I made my current USIM switch to the Pinephone (and I won't until it's usable enough for every day use).
And even then, most of my calling goes via LINE, and all the occasional normal phone calls are just 1 time calls I make to for example hospitals, restaurants, electronic stores, game centers, etc, so I never need to store contacts on my phone.
PinePhone OS & Malfunction - by tommaso - 11-21-2020, 03:00 AM
RE: PinePhone OS & Malfunction - by tommaso - 11-23-2020, 07:16 AM
RE: PinePhone OS & Malfunction - by ryo - 11-23-2020, 04:55 PM
RE: PinePhone OS & Malfunction - by tommaso - 11-25-2020, 08:46 AM
RE: PinePhone OS & Malfunction - by ryo - 11-25-2020, 04:03 PM
RE: PinePhone OS & Malfunction - by ryo - 11-21-2020, 08:25 AM
RE: PinePhone OS & Malfunction - by hiimtye - 11-21-2020, 05:05 PM
RE: PinePhone OS & Malfunction - by tommaso - 11-23-2020, 01:53 AM
RE: PinePhone OS & Malfunction - by ryo - 11-23-2020, 04:47 AM
RE: PinePhone OS & Malfunction - by tommaso - 12-12-2020, 02:43 AM
RE: PinePhone OS & Malfunction - by evilbunny - 12-12-2020, 05:25 AM
  link for supported pinephone os manjharo et all penguins_rule 3 350 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 509 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 1,908 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 2,678 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 7,784 02-04-2023, 08:35 PM
Last Post: Westslope
  Pinephone craches after each call neithan76 2 1,670 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 30,065 07-28-2022, 12:40 PM
Last Post: johaennessen
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,158 05-09-2022, 08:29 AM
Last Post: ragreenburg
  "Emergency" terminal on pinephone (with default setup) altulke 5 2,782 05-03-2022, 12:42 PM
Last Post: altulke
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 1,957 04-07-2022, 06:02 AM
Last Post: danimations
