PinePhone OS & Malfunction
I received my PinePhone with a preinstalled version of Manjaro.
I do not like this OS, I' used to work on Debian.
The received phone does not work correctly: I changed the user and it is impossible to set the date and time correctly and this does not sync with the internet time.
Main failures:
- The pacman grafic software the 2/3 of the times installs not working software
- Terminal: impossible to use a lot of normal terminal sofwtares, impossible to use different installers than pacman
- Manjaro is a very low compatibility with other linux softwares
- Manjaro offers very few softwtares, often they do not work properly
- Manjaro offers very few way of setting and personalizations
- Difficult to adapt windows to the screen
- Battery runs out of energy very quickly
- System is very slow
- It bugs
Conclusions: Manjaro is very bad, I would not suggest it at all!
Do any of you have any suggestion?
Is it possible to solve any of the problems listed?
Thanks!
PinePhone OS & Malfunction - by tommaso - 11-21-2020, 03:00 AM
RE: PinePhone OS & Malfunction - by tommaso - 11-23-2020, 07:16 AM
RE: PinePhone OS & Malfunction - by ryo - 11-23-2020, 04:55 PM
RE: PinePhone OS & Malfunction - by tommaso - 11-25-2020, 08:46 AM
RE: PinePhone OS & Malfunction - by ryo - 11-25-2020, 04:03 PM
RE: PinePhone OS & Malfunction - by ryo - 11-21-2020, 08:25 AM
RE: PinePhone OS & Malfunction - by hiimtye - 11-21-2020, 05:05 PM
RE: PinePhone OS & Malfunction - by tommaso - 11-23-2020, 01:53 AM
RE: PinePhone OS & Malfunction - by ryo - 11-23-2020, 04:47 AM
RE: PinePhone OS & Malfunction - by tommaso - 12-12-2020, 02:43 AM
RE: PinePhone OS & Malfunction - by evilbunny - 12-12-2020, 05:25 AM
  New PinePhone user issues greenpineuser 8 2,588 12-19-2024, 09:47 PM
Last Post: emilianojay
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 11,099 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 1,076 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 1,901 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 2,047 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 3,977 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 5,183 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 12,700 02-04-2023, 08:35 PM
Last Post: Westslope
  Pinephone craches after each call neithan76 2 2,747 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 39,920 07-28-2022, 12:40 PM
Last Post: johaennessen
