Pinebook Pro won´t boot either from eMMC or microSD
#34
There are 4 or more different debians so....
Run lsblk, find out which is emmc and which SD, emmc also has boot0&1 on it
If mmcbk1p2 is /, you won't be able to unmount it
Check,, mount |grep mmc
From the sounds of it, the SD is what had the bad filesystem and
now you have a different SD
So, if you have a SD carrier, put manjaro SD, in carrier, into usb port and fix it there
(lsblk again to check) It will be /dev/sda,,,, sudo fsck /dev/sda2
The reason for this, debian doesn't use pacman, so downgrading is quite hard using debian
So, fix manjaro SD, so it is bootable, then use chroot to emmc and then either
if an older kernel is in /var/cache/pacman/pkgs ,,, pacman -U linux-pinebookpro-..... OR
chroot, install downgrade, you may have to enable AUR repository in settings (of package manager)
then run,,, sudo downgrade linux
RE: Pinebook Pro won´t boot either from eMMC or microSD - by wdt - 11-12-2020, 03:56 AM
  Pinebook Pro Initial Impressions kunger 443 593,106 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,333 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 417 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 315 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 303 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 240 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 693 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 776 02-01-2024, 11:35 AM
Last Post: tomekdev
  uboot wont boot to SD card after upgrade jbradley419 7 905 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 304 01-16-2024, 09:17 AM
Last Post: jbradley419
