Pinebook Pro won´t boot either from eMMC or microSD
(10-23-2020, 04:49 PM)KC9UDX Wrote: If you have the eMMC disabled, the SD card will boot, if the SD card is bootable.
Download this image https://github.com/mrfixit2001/debian_de...226.img.xz and flash to an SD card.  If the SD card is good, and you have flashed it correctly, it will boot.
Incidentally, I fully expect that if you're used to Kali, you will like Debian much better than Arch linux.  Kali is derived from Debian.  If you still want Arch linux, I recommend Manjaro, which is Arch derived, and will be much more functional than a generic Arch build.  The Manjaro image for the PBP is the most functionally complete.  The Debian image is in my experience, more stable, and more likely to just work.  That's why I recommend Debian just to get the machine to boot.
 Thanks, I'll consider using Debian instead, I just wanted a fully customizable distro that had nothing preinstalled, but maybe I'm not ready. Big Grin
I've downloaded the image and flashed it to my microSD. But as soon as I turn the eMMC switch off it seems like the power is cut because whenever I try to reboot, nothing happens and the leds don't even turn on, no color. I'm not sure as to why this is happening. Does it need to be a specific microSD?
I have also ordered an eMMC adapter, so when it arrives I'm hoping that I can just reflash the eMMC and get it running because I think the issue is uboot, but I have never worked with this so I'm not really sure how it works.
RE: Pinebook Pro won´t boot either from eMMC or microSD - by robieguarneros - 10-24-2020, 01:36 AM
  dead Pinebook - help please RicTor 1 367 02-25-2026, 06:44 PM
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 7,737 02-09-2026, 12:50 AM
Last Post: Anthona
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 604 12-18-2025, 01:05 AM
Last Post: qingss0
  Pinebook Pro for sale rfm83 0 588 11-08-2025, 09:22 AM
Last Post: rfm83
  swap eMMC advice jceaser 2 863 10-23-2025, 09:59 PM
  Pinebook pro bricked? michaelmoua 3 5,148 10-23-2025, 10:06 AM
Last Post: jceaser
  Need new eMMC Karsten1 2 2,938 10-23-2025, 09:38 AM
Last Post: jceaser
  Bonk to boot biketool 2 1,060 10-21-2025, 09:08 AM
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 7,141 08-02-2025, 08:55 PM
  Pinebook problem meghancordo 1 4,434 07-24-2025, 07:28 AM
Last Post: mikehenson
