killed my pinebook pro with my pinephone
(07-31-2020, 09:18 AM)gracefullyparanoid Wrote:
(07-23-2020, 03:23 AM)jvlist Wrote: Well so far no luck. the debian version would not boot at all. Manjaro 20.06 does give me a green power light but no boot screen. So im gonna try another version.
I was in a similar predicament as you.  I had installed Kali Linux on my eMMC and after an update the PBP was dead.  The light would come on red and then nothing.  I could not boot to SD for any distro and the USB boot did not work. I really did not feel comfortable trying to open the case and do the eMMC switch start procedure. Partially because I felt the risk of breaking it was high and partially because my two cats believe themselves to be tech savy and always come to assist.
I ordered this from Amazon:
https://www.amazon.com/gp/product/B01LHJ...UTF8&psc=1
It was 5 dollars and another 4 to ship it and it came in three days in the mail.  Once I got it, I locked the cats out of the bedroom (lol).  Then I turned the PBP over and removed the 10 screws from the back.  The eMMC was easy to spot and popped right out.  I placed it on this eMMC reader and put it in my other computer.  I flashed Mr.Fixit's original Debian build to the eMMC using Balena Etcher.  I put it back into the PBP and it booted right up.  The eMMC adapter is an extremely helpful device to have around.
In any case, Good Luck! and I hope you resolve your problem.
I had more or less the same issue, and I solved it the same way! Buying the USB to eMMC adapter and using it to flash to the eMMC directly with another computer!
RE: killed my pinebook pro with my pinephone - by gimy16 - 08-03-2020, 02:43 AM
  Pinebook Pro Initial Impressions kunger 443 591,727 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,324 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 410 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 314 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 302 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 239 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 689 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 772 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,659 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,277 12-15-2023, 02:11 PM
