Bricked? Pinebook Pro using Uboot-pbp
(06-23-2020, 06:39 AM)tophneal Wrote: Was your Arch install from scratch? There's an Arch image that already has uboot included.
What was your battery level at before you shutdown? No signs of life is typically an indication that the battery was drained too far. (Just plug it into the barrel charger overnight.)
Also, your PBP can't brick (yay!) Try grabbing a live boot img and write it to SD. Pop it in and boot it up. If it is a borked uboot, remove the back cover, disable the emmc with the switch, and retry booting your SD.
Hello, and thanks for the reply.
I used the arch linux ARM for PBP. so then i guess the uboot was in there all along.
I had the charger inn all the time. but i will try to have it plugged inn over night annyway. Smile
YEY. didn't know that it cant brick! Big Grin thanks! have tryed with img in SD, but if the battery is drained, then thats that.
RE: Bricked? Pinebook Pro using Uboot-pbp - by hanmorten - 06-23-2020, 06:57 AM
  Pinebook Pro Initial Impressions kunger 443 595,409 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,361 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 445 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 335 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 321 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 255 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 718 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 804 02-01-2024, 11:35 AM
Last Post: tomekdev
  uboot wont boot to SD card after upgrade jbradley419 7 958 01-19-2024, 02:29 PM
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,733 12-17-2023, 09:29 PM
Last Post: insideau786
