eMMC frequently not found by Linux kernel (especially on low battery)
(06-11-2020, 12:07 PM)Arwen Wrote: Now I have noticed that booting Manjaro off eMMC was not reliable, and tracked it to U-Boot. Based on another user's forum post, I used the latest default Debian U-Boot files on my eMMC. That has made booting Manjaro off eMMC quite reliable. Perhaps I need to do the same for my Manjaro SD card.
Thanks for the suggestion! A couple of days ago I did:
cd /usr/lib/u-boot/pinebook-pro-rk3399/
dd if=idbloader.img of=/dev/mmcblk2 seek=64 conv=notrunc
dd if=u-boot.itb of=/dev/mmcblk2 seek=16384 conv=notrunc
Since then I booted the Debian from eMMC two or three times, with decreasing battery levels, and without any problem. So yes, it does look like a U-Boot issue.
But now again I cannot boot from SD card anymore, which is annoying for at least two reasons:
  1. For some reason I think video performance was somewhat better in Manjaro, so being able to use it occasionally would be nice.
  2. Should something go really wrong with my Debian system I cannot boot a rescue system.
Overall I'm quite disappointed with the state of U-Boot support for this device. I have two other ARM systems (RaspberryPi 2 and Cubox-i4) where U-Boot produces display output right from the start. This would probably even allow for a boot menu (which I only tested on yet another ARM, a CB5-311). I'm looking forward to improvements!
RE: eMMC frequently not found by Linux kernel (especially on low battery) - by v-man - 06-16-2020, 11:03 AM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 347 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,157 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 414 12-07-2023, 03:11 PM
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,446 09-07-2023, 09:38 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,983 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,488 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 665 07-13-2023, 05:21 PM
Last Post: owaspfap
  kernel module that supports usb-c hdmi alexandre 16 14,606 05-14-2023, 09:58 PM
Last Post: rathofkhan3
  Kali Linux for Pinebook Pro Luke 100 159,903 05-03-2023, 06:10 AM
Last Post: dachalife
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,507 04-01-2023, 03:22 PM
Last Post: TRS-80
