Android SD card fails
You need to use the Phoenixcard SD creator to burn the image phoenix image: https://drive.google.com/file/d/0B0cEs0l...U1NFk/view
Or you can use win32imager on windows to burn the newest DD image.
I think that the phoenix method will be easier for you as a beginner (who I am guessing you are)
First get the latest phoenix android image of the wiki.
[edit ] I will make it easy for you and just paste the link here Wink http://files.pine64.org/os/android/andro...ixCard.zip
Unzip the image. Then download the Phoenix SD creator (link above). Run the creator, chose the image, point it to where your SD card is (drive) - make sure its set to the correct drive -  set 'Startup!', format to normal, and burn.
Android SD card fails - by bluebird1002@ymail.com - 05-09-2016, 03:25 PM
RE: Android SD card fails - by Luke - 05-09-2016, 04:49 PM
RE: Android SD card fails - by Luke - 05-11-2016, 05:51 AM
RE: Android SD card fails - by tkaiser - 05-11-2016, 09:56 AM
RE: Android SD card fails - by Luke - 05-11-2016, 12:29 PM
RE: Android SD card fails - by Denny Crane - 05-26-2016, 09:45 AM
RE: Android SD card fails - by Ghost - 05-26-2016, 12:28 PM
RE: Android SD card fails - by Denny Crane - 05-26-2016, 12:47 PM
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 1,937 03-18-2021, 11:52 AM
Last Post: Avron
  How to boot from SD card on pinebook pro linux123 3 6,122 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 4,489 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,396 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,484 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 213,686 03-03-2020, 11:34 PM
Last Post: siyatalerja
Question Do I need a touchscreen to run Android? chrbar 3 5,162 08-08-2018, 10:55 PM
Last Post: chrbar
  ethernet lan speed problem android fulltone 0 2,640 04-23-2018, 01:47 AM
Last Post: fulltone
  eMMC card on adapter Malmgren 8 11,290 03-20-2018, 11:14 AM
Last Post: Malmgren
  No sound on Android 6 or 7.1 reeno 0 2,929 07-29-2017, 06:31 PM
Last Post: reeno
