Kali Linux for Pinebook Pro
#31
Hi all,
my Pinebook Pro is able to boot from the emmc but I have no network connection, although I can see my wifi network, and till now I was not able to find a way to activate it.
Any ideas?
Best regards, happy and healthy hacking!
Ricardo
I was able to boot from the emmc once. I didn't spend too much time diagnosing the issue, but one thing I noticed was that it does not appear the image has a separate boot partition. This might not be a big issue, but it seemed a little odd.
I was surprised to see Kazam is installed by default.
With 2020.1 it was fully working, but with 2020.2 audio is broken, also with root.
I'm using the 2020.02 image for Pinebook Pro from offensivesecurity. I flashed it to microSD with dd, but can't get it to boot. I tried flashing recalbox to the same SD card and it booted fine. I think I need to edit extlinux, but I'm not sure how to - the linked Kali bug addresses not being able to boot from eMMC.
Any ideas? TIA!
Kali 2020.2 for PBP works like a charm flashed on SD with no extra steps needed. Using it for my regular needs (messaging, compiling, programming, different IDE's, testing web server/client, network, cryptography, steganography, forensic, drone control, etc) for about 2+ weeks. More than enough software is available from apt or can be compiled from source. The only issue is that I was not able to make ALFA AWUS036ACS work with PBP for now(update: already compiled and working).
I did a test of Kali from an SD and it worked great. So I flashed it to the eMMC, rebooted and worked well.
But then I ran sudo apt upgrade and now it doesn't move past a black screen after reboot. Both when booting from the eMMC and now I can't even install Kali from the sd card. The red power light comes on but it doesn't turn green and just hangs there.
Is there something from the upgrade process that may be preventing my PBP from booting to the SD?
(06-05-2020, 09:19 PM)AustinFoss Wrote: I did a test of Kali from an SD and it worked great. So I flashed it to the  eMMC, rebooted and worked well.
I had that same issue before. This is a known issue. I flashed manjaro to emmc with adapter. It is probably possible to flash without adapter using emmc switch (pbp wiki or search forum).
Has anyone had any luck running Kali in a VM, on the pinebook pro? What software and image did you use?
Didn't Kali switch to Xfce? What video driver is it using? I thought Mali T860 only did Wayland and Xfce only does Xorg, so might be using llvmpipe. Figured that's why KDE is working well, because of Wayland support.
Anywho, if they got hardware acceleration working with Xfce I might just have to buy one of these as a backup Xubuntu machine.
panfrost works with drm, wayland, and x11
  Debian on Pinebook Pro u974615 7 1,235 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,703 02-22-2024, 04:02 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 364 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,207 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,286 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,684 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,301 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,441 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,531 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,633 08-07-2023, 01:12 PM
Last Post: myself600
