Does anyone know if it is possible to install a devuan gnu/linux ?
I get a bit lost with architecture, I can't find image for pinebook pro.
You know if you can install a devuan. You know freedom software
Without systemd 8=]
a greeting
Idk about devuan. Probably more luck with artix linux (manjaro openrc's successor) since it is more active.
(10-10-2019, 11:48 AM)erosketak Wrote: I get a bit lost with architecture, I can't find image for pinebook pro.
Without systemd 8=]
a greeting
If you are only interested in the systemd aspect, then you are lucky. The preinstalled OS is Debian 9. I don't know about Debian 10, but it's quite easy to run Debian 9 without systemd. Just uninstall it and apt-get automatically pulls in sys-v. The only remains is the systemd shim layer libsystemd0.
On my intel laptop, I run Debian 9 with sys-v and it works like a charm. I expect this to be true for the Pinebook Pro, although I have not tried it.
Has anyone had any luck with Artix on the PBP?
Short answer: yes. There's a thread in the tutorial section of this forum (and actually, a number of them across the web) explaining how to convert a Debian install into Devuan. I've done it successfully with the original (Mr Fixit) Debian image, but don't see why it wouldn't work with a newer build.
You can simply Replace systemd as your init system and leave systemd in place to appease app dependencies (apt-get install sysvinit-core sysv-rc-conf - this automatically de-installs systemd-sysv. I believe this is basically what MX-Linux does). Or you can wipe systemd completely and switch to the Devuan repositories (this is a bit more involved. Best to read through the tutorials)
hack danielt's debian installer and use a devuan debootstrap instead.
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 401 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  install debian on pbp jsch 7 4,192 11-22-2023, 04:22 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,583 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,681 08-07-2023, 01:12 PM
Last Post: myself600
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,198 07-15-2023, 02:58 PM
Last Post: u974615
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 695 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 162,064 05-03-2023, 06:10 AM
Last Post: dachalife
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,588 04-01-2023, 03:22 PM
Last Post: TRS-80
  unsuccessful re-install of OS for PineBookPro Valiance 3 1,374 02-14-2023, 12:49 PM
Last Post: Valiance
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 1,241 11-28-2022, 05:03 PM
