Hello my frend. How to fix my boot problem?
Tongue
I am a new user in Linux and a new owner of a pinebook pro from Russia Smile . How to fix booting after incorrect installation of Manjaro?[Image: 8352IMG_0859_800.jpg][Image: i.gif][Image: IMG_0858_800.jpg][Image: i.gif]
i installed uboot-pinebookpro-bsp visual artifacts disappeared, in which direction to look, prompt to fix errors:
[ 1.830285] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22
[ 2.509700] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 2.936889] rockchip-dp ff970000.edp: no DP phy configured
[ 3.059417] usb 2-1.2: device not accepting address 3, error -71
until the software problems are solved, I decided to decorate the appearance Smile [Image: IMG_0861_800.jpg][Image: i.gif], [Image: IMG_0862_800.jpg][Image: i.gif], [Image: 41472IMG_0863_800.jpg][Image: i.gif]
Probably your easiest route at this point is just to reinstall Manjaro (or your choice of other operating system) anew.
You can write a bootable image to micro-sd card and boot that, and then install to eMMC. Or, you can remove the eMMC and flash it in another computer with an adaptor.
:wq
(07-03-2021, 08:16 PM)KC9UDX Wrote: Probably your easiest route at this point is just to reinstall Manjaro (or your choice of other operating system) anew.
I have already reinstalled many times from micro sd to emms. all I have achieved is the green artifacts on the screen have disappeared and the errors remain. there are no errors when booting from a micro SD image mrfixit2001.
Well, you probably don't want to hear my opinions about Manjaro. Smile I do have it running on my wife's PBP, but I only update it every six months and so far have been lucky, I guess. My PBP runs NetBSD, and (now very, very rarely) the mrfixit2001 Debian.
:wq
In that case you can try to install the U-boot from mrfixit2001.
Perhaps this thread can help: https://forum.pine64.org/showthread.php?tid=10031
  Charging problem RicTor 4 2,710 07-28-2026, 08:10 PM
  Pinebook problem meghancordo 2 6,959 03-18-2026, 08:58 AM
Last Post: RicTor
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,220 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 2,803 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 32,765 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 20,183 04-03-2025, 07:47 AM
Last Post: Tazdevl
  Problem with Wifi, Sleep, Video and PGP signature Anarethos 4 6,781 03-31-2025, 07:14 AM
Last Post: Anarethos
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 6,471 02-05-2025, 03:56 AM
Last Post: waylonwesley
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 12,775 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,491 12-25-2024, 10:12 PM
Last Post: jessipinkman
