Getting started with an Old PineTime dev kit (flash procedure?)
So i've dusted of my old pinetime dev kit. Beforte the infinitime 0.7 firmware. Just the closed source firmware.
Here is my plan. Will it work or will it brick?
-> Flash new bootloader with BLE with the DaFlasher App
Like described on the WaspOS tutorial*:
1) flash 'hacked'
2) flash 'dafit..'
3) and then?
The documantation says flash 'bootloader-daflasher.zip'. But i can't find that file anywhere.
I think that, finishing stages 1 and 2 will give me a 'unlocked' pinetime. And i can flash the waspos 4.1 firmware.
? Is this correct?
Or can i then follow the infinitime instructions**
1) flash inifitime 1.x
2) flash bootloader
3) flash recovery
I expect that i have to flash a wasp/infinitime bootloader first. That 'bootloader-daflasher' that seems missing..
Help appreciated!
*Installation Guide — WASP-OS documentation
**InfiniTime/gettingStarted-1.0.md at 1.2.0 · JF002/InfiniTime · GitHub
I can't recall anyone going through that process. Might be doable but you're on your own mostly.
It's significantly easier to simply use a hardware programmer (not a ST-Link v2) and flash it that way, it is a devkit after all.
(07-01-2021, 04:13 AM)Avamander Wrote: I can't recall anyone going through that process. Might be doable but you're on your own mostly.
Stlink won't work right away, as the bootloader on the initial kit is locked. I'll need a rasp pi. However, daflasher and the man bevind daflasher found the way to fix that (in a ota blue way, nice!)
https://wiki.pine64.org/wiki/PineTime_FA...tection.3F
Follow the wasp-os instructions to completion with one exception. Instead of installing micropython.zip install reloader-factory.zip instead. That will leave you running Infinitime Light. From there you can following the Infinitime OTA upgrade docs to get the latest Infinitime running.
I would suggest using the latest CI binaries for the wasp-os parts of the process. If you use the wasp-os v0.4 binaries you will end up with much older version of mcuboot.
For the specific instructions you want from the wasp-os documentation see:
* Install the wasp-bootloader: https://wasp-os.readthedocs.io/en/latest...or-android
* Install reloader-factory.zip: https://wasp-os.readthedocs.io/en/latest...-daflasher
(07-01-2021, 06:55 AM)danielt Wrote: Follow the wasp-os instructions to completion with one exception. Instead of installing micropython.zip install reloader-factory.zip instead. That will leave you running Infinitime Light. From there you can following the Infinitime OTA upgrade docs to get the latest Infinitime running.
Thanks for the reaction and suggestion!
In the instructions there's the part of
'Click Select DFU file again and select bootloader-daflasher.zip. Once the update is complete the watch will show the wasp-os logo and some additional on-screen prompt.'
But i'm lost at the 'bootloader-daflasher.zip'. Where can i find this file/bootloader?
It is off course in the binary zip / zip you create when compiling.
Thanks for the help Daniel
(07-01-2021, 12:30 PM)Meurton Wrote: In the instructions there's the part of
No worries.
BTW bootloader-daflasher.zip is also included every binary release too.
wasp-os uses a different packaging approach to Infinitime. For wasp-os you don't download each file individually. Instead there is a single file called wasp-os-<version-number>.zip (or .tar.gz if you prefer) which contains everything related to that release. You download the single file, extract everything from it and find the binaries appropriate for your device (which for PineTime are in build-pinetime/ ). CI builds are structured a tiny bit differently but the same idea applies... download a single file and extract it.
(07-01-2021, 04:32 AM)Meurton Wrote:
(07-01-2021, 04:13 AM)Avamander Wrote: It's significantly easier to simply use a hardware programmer (not a ST-Link v2) and flash it that way, it is a devkit after all.
Yes, that's what I wrote.
(07-01-2021, 04:32 AM)Meurton Wrote: I'll need a rasp pi.
There are other, better options as well.
(07-01-2021, 04:32 AM)Meurton Wrote: Stlink won't work right away, as the bootloader on the initial kit is locked. I'll need a rasp pi. However, daflasher and the man bevind daflasher found the way to fix that (in a ota blue way, nice!)
Code to remove the hardware lock is present in the wasp-reloader too (although if Aaron has it working in Daflasher then I doubt you will need it). Thus if you only have a STLink but you can get the BLE OTA sequence to work then there should be no need to set up another SWD programmer!
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 2,733 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 3,144 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 10,082 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 4,585 07-30-2025, 11:44 PM
Last Post: karthick
  ? Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 2 1,662 07-29-2025, 04:49 AM
Last Post: oscar-gardiazabal
  PineTime charging issues - connecting pins black gsoundsgood 2 2,724 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 4,264 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 8,791 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 5,114 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 1,918 01-31-2024, 11:57 AM
Last Post: tynstar
