Pinebook pro nearly unusable after using manjaro-arm-installer
Good afternoon everyone, about a month ago I tried using the manjaro-arm-installer script to flash the emmc. This completely bricked my device, no booting from emmc or sd card, not even the green LED power light would come on. Finally got around to opening the thing up and hitting the RESET button. This got booting from the sd card working again, but the performance is absolute garbage. I can get to the manjaro KDE desktop but it will freeze if I try to do anything useful. I'm at my wit's end with this thing, any guidance you can offer would be greatly appreciated, Thank You!
(06-18-2021, 03:34 PM)TheCounselor Wrote: Good afternoon everyone, about a month ago I tried using the manjaro-arm-installer script to flash the emmc. This completely bricked my device, no booting from emmc or sd card, not even the green LED power light would come on. Finally got around to opening the thing up and hitting the RESET button. This got booting from the sd card working again, but the performance is absolute garbage. I can get to the manjaro KDE desktop but it will freeze if I try to do anything useful. I'm at my wit's end with this thing, any guidance you can offer would be greatly appreciated, Thank You!
I find KDE to be heavy on an SD card (arguably, on the eMMc as well), so I prefer Xfce, gnome, i3 or sway, any of these are much better in my experience.
As for not being able to run manjaro from the eMMc, only the SD, installing bsp uboot could do the trick, I have to use it with Manjaro and Arch otherwise it won't boot.
Give Armbian a try.
Cheers,
TRS-80
Protocols, not Platforms
  Boot Order in Pinebook Pro food 12 16,275 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 5,140 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,626 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,037 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,498 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 6,548 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 7,783 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,304 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 11,500 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 3,822 03-08-2024, 08:41 AM
