Pinebook Pro Manjaro Power Savinng Tips
How can I minimize power usage in Manjaro(e.g. turning off CPU cores, lowering default brightness, etc.)
(06-14-2021, 07:01 PM)HelpMyBatteryIsDraining Wrote: How can I minimize power usage in Manjaro(e.g. turning off CPU cores, lowering default brightness, etc.)
The same way you can do that in almost any other Linux distro. Your UI options will depend on the desktop environment you choose to run - e.g. in KDE there is a slider when you click on a battery icon in your tray. You should be able to use your keyboard too, Fn+F1/Fn+F2 should be the keys. As to turning off CPU cores - you wanna play around with values in /sys/devices/system/cpu/cpu#/online - you can read them, and, as root, write to them.
Generally though, don't be afraid to use search engines for such basic questions - they won't bite you, and searching for something like "linux turn off cpu core" or "manjaro adjust display brightness" will yield exactly what you're looking for among the very first few results, and typically much faster than if you wait for the answers on a forum.
This message was created with 100% recycled electrons
  Boot Order in Pinebook Pro food 12 17,844 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 5,930 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,978 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,402 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,012 03-15-2025, 01:47 AM
Last Post: frank_philip
  PBP does not power on (or only 1 in 10 times) zkajdan 2 3,915 02-27-2025, 12:10 PM
Last Post: zkajdan
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,102 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,299 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,566 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,141 03-31-2024, 10:11 AM
Last Post: u974615
