Screen is blank on pinecil - did I kill it?
I was using my pinecil today to do some soldering, I was running it off of my power bank cause I thought it would be enough power.  I ended up having issues with one of the larger components so I decided to pull out my AC adapter that I have to get some extra power.
I have a 24v AC adapter that I had bought for my TS100.  I plugged that up and when I plugged it into the pinecil I got nothing.  I then plugged it back into the power bank and the screen was still blank.
I do have a USB power meter plugged in between the power bank and the pinecil.  It shows 5v 0.3a when plugged in, so it's not completely dead.
I plugged my TS100 into the AC adapter and it worked fine.  I know they now recommend 21v max now, but I was under the impression it could handle the 24v just fine.  I am assuming this is my issue since it worked fine until I switched power supplies, but would that cause what I am experiencing?  Is there any place to buy replacement screens for the pinecil?  I know I can buy screens for the TS100, are the compatible?
Open to any and all suggestions.  Thank you.
Hey! Did you get an answer to this? I did the same with the same result and am not sure if I need a new one
Hi Gents,
Same thing happened to me.  I can get the Pinecil to flash over dfu mode...  where you able to revive it?
Maybe hop over to the GitHub discussion if you're still trying to fix it.... https://github.com/Ralim/IronOS/discussions/988
-DD
  pinecil v2 dosent negotiate power moses 0 1,379 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 947 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 1,361 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 3,560 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 1,329 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,754 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 2,200 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 5,102 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 10,016 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 6,891 05-15-2025, 10:41 AM
Last Post: dreieck
