PinePhone Beta Edition will not boot from MicroSD card
My beta edition PinePhone will not boot from the SD card. I was getting the red notification light, but it never got past that.
I tried two different Micro SD cards that work in a different beta edition PinePhone, but they would not boot.
Also, I tried putting a Micro SD card in without a OS to see if I could see that when booting from the emmc, but the phone would not boot then. I inserted the Micro SD card after the phone was on (don’t know if this was a bad idea or not) and then I was able to see it.
I am putting it in the correct slot though I wish that was the fix Smile
Anyone have an idea on what could cause this?
Solution: This was caused by a issue with the card detection pin. Using the modified version of U-boot set to ignore the card detection pin is a workaround for if the card detection is broken. https://forum.pine64.org/showthread.php?...775&page=3
I would try reflashing the SD Card, On my UBports edition will do the same thing when it encounters an SD card that it cannot boot from. I personally use etcher for flashing images to SD card.
(04-26-2021, 11:14 AM)Captain1ndustry Wrote: I would try reflashing the SD Card, On my UBports edition will do the same thing when it encounters an SD card that it cannot boot from. I personally use etcher for flashing images to SD card.
Sadly I already tried that, thanks anyway. Just got a new SD card today and that one will not boot in this phone either, but it will boot in another PinePhone I have.
Sometimes when my PinePhone gets stuck and I force a poweroff it seems that the hardware will get stuck in a non-self recovering state (red led lit for more than 1 minute). When this happens I remove the battery, and in succession hold the power button, volume down, volume up, volume down, and finally power for 8 seconds each. I then reinstall the battery and the PinePhone boots properly.
Mark
Quote:Sometimes when my PinePhone gets stuck and I force a poweroff it seems that the hardware will get stuck in a non-self recovering state (red led lit for more than 1 minute). When this happens I remove the battery, and in succession hold the power button, volume down, volume up, volume down, and finally power for 8 seconds each. I then reinstall the battery and the PinePhone boots properly.
Mark
Thanks for the suggestion. Just gave this a try and still only get the red light. I can boot from the emmc, but can't boot from any of the SD cards I have tried. The SD cards do work in another pinephone just not this one, so I don't thing they are the problem.
It definitely seems to be something wrong with the phone.
(04-26-2021, 04:56 PM)Timothy_Ecc Wrote: Thanks for the suggestion. Just gave this a try and still only get the red light. I can boot from the emmc, but can't boot from any of the SD cards I have tried. The SD cards do work in another pinephone just not this one, so I don't thing they are the problem.
The fact that I gets stuck when you have an SD card installed indicates to me that the PinePhone detects the card. Maybe there is a dirt film on one of the contacts for the SD card. Try a business card cut to fit in the slot with some isopropyl  alcohol. Be gentle/careful and fully dry before powering it back up.
Mark
(04-26-2021, 05:57 PM)mark1250 Wrote: The fact that I gets stuck when you have an SD card installed indicates to me that the PinePhone detects the card. Maybe there is a dirt film on one of the contacts for the SD card. Try a business card cut to fit in the slot with some isopropyl  alcohol. Be gentle/careful and fully dry before powering it back up.
Mark
Interesting idea I gave it a try, but it didn't help. I wonder if there is any way to check the software/hardware that boots from the SD card.
If an SD card has previously had an OS flashed to it you need to zero out the first few bytes or it will cause the device to not boot to emmc.
(04-29-2021, 10:44 PM)MtnSk8 Wrote: If an SD card has previously had an OS flashed to it you need to zero out the first few bytes or it will cause the device to not boot to emmc.
Good point. That is likely why I was unable to boot when I had a SD card without a OS on it since I did not zero out the first few bytes after wiping the card.
Thought I still can't figure out why I can't boot from a card that boots in another PinePhone.
Hi @MtnSk8 (and anybody else).
I'm having exactly the same problem as the OP.
Brand new SD card.
I have a Pinephone Convergence Beta edition.
Running lsblk on the phone, it actually sees the sd card.
However, no matter what I seem to try, I cannot boot it to either PostmarketOS as flashed to the SD card, or to Jumpdrive (developed by some of the Postmarket developers).
This may be a dummie question, but, in reference to your answer:
HOW do I zero "the first few bytes" of the SD card,
and exactly how many is the first few?
1?  2? 8? 16? 512? 1024?
I took a gamble on this from pinephone documentation
https://wiki.pine64.org/index.php/PinePh...structions
and tried:
sudo dd if=/dev/zero of=/dev/[DEVICE] bs=8k seek=1 count=4
But have no idea if that's what you mean.
Anyway, it didn't help.
I am flashing using standard dd method  (having first run unxz to decompress the postmarket.img.xz file)
sudo dd if=postmarket.img of=/dev/sdXX status=progress
and also trying to flash using the interesting postmarket.img.xz  piped through dd as described in postmarket documentation
https://wiki.postmarketos.org/wiki/JumpDrive
xz --decompress --stdout pine64-pinephone.img.xz | sudo dd of=/dev/mmcblk... status=progress
In this case, I think the instructions are indicating doing this on the pinephone itself, but I am flashing it to the SD card using my linux desktop,
so
    /dev/mmcblk...
becomes
    /dev/sdXX
Thanks anybody for any help or advice
  New PinePhone user issues greenpineuser 8 8,565 12-19-2024, 09:47 PM
Last Post: emilianojay
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 4,151 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 4,872 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 5,155 04-02-2024, 11:52 AM
  Boot fails ionmich 6 7,979 11-02-2023, 05:14 AM
Last Post: Uturn
  How do I import SIM card contacts? Logological 8 15,147 06-04-2023, 12:49 PM
Last Post: mruser1
  new PinePhone upgrade issue WhiteHexagon 5 7,992 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 9,107 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 19,804 02-04-2023, 08:35 PM
Last Post: Westslope
  Manjaro plasma-mobile Beta 13 Uturn 13 17,155 01-25-2023, 04:15 PM
