What native PinePhone application would you like to see in the near future?
#41
(02-03-2021, 03:34 AM)kern707 Wrote: What native (mobile optimized) applications would you like to see becoming available for the PinePhone in the near future?
I am not talking about existing applications that are currently not compatible, I am talking about applications that exist on other platforms (such as Android), but are not available for linux phones, and that you would love to have on your PinePhone.
This thread is in order to put together some opinions, that will help developers decide what the end-customer really need / want on their PinePhone, and maybe give it a higher priority.
Any input will be very much appreciated :-)
So right away I feel the need to point out that the PinePhone supports multiple OSs (which they have no control over)—all which vary for support for apps in different ways.
For example, SailfishOS, as I understand it, can actually emulate some Android apps and run them. Arguably, SailfishOS also already comes preloaded with a decent array of native apps (i.e. not Android/iOS) most would probably get use of right out the box. Other OSs like PostmarketOS or Manjaro offer what they do based on their decisions but are also limited to the desktop environment they shuffle. In the case of Manjaro, I believe they like PlasmaMobile... which is KDE whereas others like Mobian make use of Phosh which uses Gnome. Yes, I know there is nothing from stopping someone from running either desktop-distro pairing on whichever distro has an image compatible with the device... I'm merely trying to ingrain the notion that depending on what you decide to use, you HAVE guaranteed things that already work.
What I'm sure this is yet another post for getting Android/iOS apps ported to one of the OSs... in which case this entire thread is misguided if not pointless.
Pine64 has no control over what apps get developed or ported over to projects or distros they obviously do not even manage.
If your intent is to give devs some incentive to develop some app that exists in the Android/iOS space but not on Linux, then I recommend you actually go and bug the developers for those apps. The folks involved with projects like Mobian and PostmarketOS aren't likely to be able to do anything for you regardless of whatever popularity contest is held here.
Just my 2 cents.
P.S. Android emulation is something I believe most projects are aware of and perhaps are investigating still but go figure...
Just my 2 cents.
Just some random points for you.
I think you're missing the whole point of the thread. It's a few random people sitting around and talking about what's missing from the PinePhone universe, not requesting any specific person/group to write the applications; since this is the first REAL phone, that I could even think about coding for I find the thread useful.
I'm pretty sure everyone knows that PINE64 is just the hardware vendor, and applications come from sources other then PINE64.org/com - It's pretty obvious.
I can expand on this if you'd like, however, going back to the early history of Linux may not be useful at this time, and your post shows you probably know the history. So I'm not going to bore you with it.
Cheers, and I would love to hear what app(s) you'd like to see running on the PinePhone.
Apps or even an app function request is great here.
if you are a linux user, desktop or mobile(ie N900/Maemo), you can also post the source code link to a favorite app, it makes it easier to add to a testing or unstable repo.
Most of these can just be added to an autobuilder and it makes it only a bit of work to adjust the GUI.
In that case : there was a Bitwarden client written in Vala abandonned 3 yrs ago. Was wondering if it was a viable base for a mobile client ...
1st post, as I'm waiting for my pinephone to arrive.
Anyhow.... Here's my list of regularly needed apps: Flashlight, Calculator, Calendar, Email, contacts, file explorer, and a good music player!  Cool
(04-04-2021, 01:14 PM)1madfitter Wrote: 1st post, as I'm waiting for my pinephone to arrive.
Hi! Are you waiting for the Mobian Community Edition? I thought they were all shipped out.
In any case, you will find all of these already in Mobian and other operating systems (except on Plasma Mobile, I don't think there's an email client yet). I mostly use Mobian myself, the Lollypop music player is pretty great and my Anker Mini bluetooth speaker works fine with it. I haven't tried to set up contacts, email and calendar yet.
Sorry for the late reply. I'm waiting on the beta edition convergence package. Thanks for the info!
I would really like to have a decent bible-reading app, and an HP41CX emulator. A solid solution for running Android apps would deliver both, and a whole lot more.
(04-13-2021, 05:00 PM)nelstomlinson Wrote: I would really like to have a decent bible-reading app, and an HP41CX emulator.  A solid solution for running Android apps would deliver both, and a whole lot more.
here is the source for a QT HP41cx emulator
https://sourceforge.net/projects/hp41cx/
How would a bible reader differ from a regular ebook reader like fbreader?
I would need a description of the tool required as I am not sure how an English or other translated bible works or is typically used/studied, in the Hebrew scriptures and later voluminous Aramaic texts with even more voluminous traditional commentary upon commentary an in text proto HTML referencing system is in use so maybe a wikified version of your texts with links converted to a ZIM for use with kiwix would be preferred?
https://github.com/geometer/FBReader/
I think fbreader is already in the unstable repos for most pinephone distros, kiwix has a plugin that should work for Firefox.
https://www.kiwix.org
``How would a bible reader differ from a regular ebook reader like fbreader?''
I'm not familiar with fbreader.
A bible reader knows about chapter and verse, and can switch between versions, and between bibles and commentaries, and can work with dictionaries and concordances.  On androids, I use mysword, https://www.mysword.info/
Thanks for the pointer to the emulator.  I'll try that on my desktop while I wait for the Pinephone.  On my Blackberry I'm using Desmet's emulator,https://sites.google.com/site/olivier2smet2/home/go41cx.
  PinePhone Game Thread PixelPaintbrush 31 80,700 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 22,633 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 7,080 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 7,240 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,019 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,293 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,833 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,417 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 6,963 10-21-2025, 12:12 PM
Last Post: Richy_T
  Does PinePhone support long-term battery health optimization? roseblack 5 3,275 10-06-2025, 09:05 PM
Users browsing this thread: 10 Guest(s)
