Pinecil rattle?
Just received my pinecil from the 2nd production run, and something is loose inside it?
It's not just the buttons - if i hold both of them down and shake it, i can still hear something moving around inside it.
Couldn't resist. Exploratory surgery suggests that the only thing that could possibly be loose is the outer contact ring in the DC barrel, which is perfectly fine because it's a spring.
Just got mine today, it has the same rattle. Maybe this is normal since my Pinecil seems to work just fine, the rattle sound is not that noticeable to me. It should be easy to tear down and see what it is, but I don't want to ruin the grip.
Got mine today and it has a rattle to it also. Pulled it apart and it seems to be something inside the DC barrel jack or the USB port. Iron functions as expected over USB-C however. Unable to test the DC barrel jack.
  pinecil v2 dosent negotiate power moses 0 459 07-07-2026, 07:28 AM
Last Post: moses
  Pinecil low temp mods? davidcoley 0 579 06-21-2026, 02:53 AM
Last Post: davidcoley
  my pinecil v2 is not working jagrav 0 975 04-17-2026, 06:28 AM
Last Post: jagrav
  Pinecil V2 doesn’t power on under any circumstances BigCarrotLeaf 1 2,967 03-28-2026, 02:37 AM
Last Post: Juptin
  Pinecil v2: Use car battery for power? FZB 0 966 03-02-2026, 09:56 AM
Last Post: FZB
  Is Vector3d.shop a legitimate pinecil reseller? jamespo 0 1,361 12-03-2025, 07:40 AM
Last Post: jamespo
  Minimum temperature Pinecil pschalkwijk 1 1,689 10-16-2025, 10:40 PM
  Pinecil v2 not reaching 20v … Escape75 0 4,738 09-23-2025, 09:25 PM
Last Post: Escape75
  Pinecil v2 tip screw temperature Minuen 0 9,553 06-23-2025, 06:38 AM
Last Post: Minuen
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 3 5,960 05-15-2025, 10:41 AM
Last Post: dreieck
