Working modem?
#31
Only other possible thing i can think of is an intermittent connector in the sim tray.
(03-03-2021, 07:37 PM)Barugon Wrote:
(03-03-2021, 07:15 PM)rocket2nfinity Wrote: Have you physically opened the case to see if the antenna connector is connected? It's the long cable on the left, snaking down from the main board to the usb board.
I assume you mean take out the screws and really open it up. I have only taken the back off to get at the microSD and SIM cards.
[edit] Yeah, it's connected.
Just to mention that my mobile connection became intermittent, and the cable _seemed_ to be on okay, but then I removed it and put it on again anyway, and it's been solid since then.
(03-04-2021, 10:18 AM)desca Wrote: Just to mention that my mobile connection became intermittent, and the cable _seemed_ to be on okay, but then I removed it and put it on again anyway, and it's been solid since then.
I'll give that a try.
Have you tried a different SIM? A lot of folks are having serious trouble with AT&T.
(03-04-2021, 07:44 AM)rocket2nfinity Wrote: Only other possible thing i can think of is an intermittent connector in the sim tray.
I think this is part of the problem. If I wedge a piece of folded paper behind the sim card when I insert it then I'm pretty easily able to get a 3G connection at least.
  4G VoLTE calls confirmed working with carrier x dcinoz 17 39,112 10-07-2025, 11:05 AM
Last Post: baptx
  MMS sending stopped working amindfv 7 8,176 05-04-2025, 01:36 PM
Last Post: zetabeta
  Modem crashes worsening from daily to multiple times a day + sms delaysFor people car bacydentir85 2 4,111 02-03-2025, 01:34 PM
  My new phone stopped working. gunnygee 3 4,885 12-12-2024, 01:21 PM
  Modem white list aular 7 7,240 02-13-2024, 04:35 PM
Last Post: aular
  qcell modem id aular 6 6,451 01-15-2024, 10:05 PM
Last Post: aular
  Temporary fix for Modem Not Coming Back on in SXMO Postmarketos Pinephone kebab 2 5,820 07-16-2023, 11:14 AM
Last Post: kebab
  Modem gets disabled on every suspend jojuma 5 7,385 03-27-2023, 02:51 AM
Last Post: jojuma
  Modem audio settings jack1 2 4,040 02-04-2023, 04:01 PM
Last Post: jack1
  Instructions to get pinephone working on USA carrier omarcomputing 1 4,401 10-08-2022, 04:45 PM
Last Post: treebeard
