Troubleshooting ROCKPro64
I recently bought a 4GB ROCKPro64 (including power supply) and am unable to make it boot. I have a serial adapter (running at 1500000bps) connected and have tried the following: There is no output following the output messages listed above and the board is not responsive to serial input.  I have tried 2 different SD cards (SanDisk Ultra 16GB A1) and in all cases, verified the data written to the card against the original image file.
Based on RockPro64 boot sequence, the "U-Boot TPL" lines suggest that the TPL is loading but the lack of a subsequent "U-Boot SPL" line suggests that the subsequent SPL loader is not starting.  The ayufan boot prompts are different but I'd expect something similar to my Rock64, which starts:
DDR version 1.13 20180428
In
SRX
LPDDR3
786MHz
I have tried raising a support ticket but, after more than a month, that has gone nowhere - the only suggestions have been to run a memory test, without actually providing any suggestion as to where I might find a memory test that doesn't require a fully functional U-Boot.  Can anyone here suggest additional troubleshooting steps I can perform?
(03-01-2021, 02:30 AM)alephnull Wrote: I recently bought a 4GB ROCKPro64 (including power supply) and am unable to make it boot. I have a serial adapter (running at 1500000bps) connected and have tried the following: There is no output following the output messages listed above and the board is not responsive to serial input.  I have tried 2 different SD cards (SanDisk Ultra 16GB A1) and in all cases, verified the data written to the card against the original image file.
In
SRX
LPDDR3
786MHz
Hi, you eventually could try to erase the spi and flash it again (https://github.com/sigmaris/u-boot/wiki/...oot-to-SPI)
In
SRX
LPDDR3
786MHz
I reproduce the same behaviour when the RXD (white wire) is connected (see https://forum.pine64.org/showthread.php?tid=6387). Try to disconnect this wire and reconnect it after the boot.
In
SRX
LPDDR3
786MHz
Thanks for that.  I can confirm that if I disconnect the RXD until after U-Boot starts then everything works.  That's a particularly nasty bug in the boot ROM but I think I can work around it (once configured, I won't have ready access so manually connecting wires isn't possible).
  where to get debian 12 image for rockpro64? heocb 1 3,291 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 2,856 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 4,205 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 3,768 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 4,914 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 3,973 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 11,467 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 4,296 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 5,350 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 6,865 03-19-2023, 06:22 AM
Last Post: runyor
