microsoft teams install problem
hai  i am Jip ,  not very handy with computers, but do not want to support the big companys that make the rules.  I feel a little lost here with my computer and do not know who to ask for help.  i try to install teams from microsoft for my kids school lessons...   but i fail somehow.  i installed  snapd and restarted after that i tried the command
sudo snap install teams-insider
on terminal   but  it will not accept the command....
earlier it accepted the command, but i could not type my password.
what do i do wrong? Huh
the real issue you're having is that snap package only supports AMD64, not ARM64: https://snapstats.org/snaps/teams-insiders
Your best bet is likely to use a chromium-based browser and use Teams through that. Honestly, having to use teams on multiple platforms, this is the way to go, to avoid Teams' very terrible custom/annoying notifications and make use of the system-wide notification system.
You could try this version made for RPi: https://snapstats.org/snaps/teams-for-linux but it's supported architures only include armhf and amd64, so some work may be required to get it working well on the PBP, without the need to install armhf libraries. the devs offer an arm64 deb file you should be able to use: https://github.com/IsmaelMartinez/teams-..._arm64.deb
for anyone else using arch/manjaro, this is also available in the aur: https://aur.archlinux.org/packages/teams-for-linux/
https://docs.microsoft.com/en-us/microso...ents#linux but no ARM Sad
I'm shocked they have Teams at ALL for Linux. I've been using it on my laptop (Dell) with Pop_OS for the past year. It's been... Ok I guess. It's still missing a lot of features that the Windows/Mac clients have.
  Charging problem RicTor 4 1,447 07-28-2026, 08:10 PM
  Pinebook problem meghancordo 2 6,047 03-18-2026, 08:58 AM
Last Post: RicTor
  Problem with Wifi, Sleep, Video and PGP signature Anarethos 4 5,905 03-31-2025, 07:14 AM
Last Post: Anarethos
  Use SD to install new OS over pinebook debian Rudy558 10 28,499 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 5,952 02-05-2025, 03:56 AM
Last Post: waylonwesley
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 7,287 08-03-2023, 03:30 PM
  Followed the blog post to install Fedora: PBP not booting anymore koenigs 6 7,128 06-01-2023, 10:58 AM
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 5,272 02-21-2023, 01:49 AM
Last Post: repa
  MiniConda Install Issues nixyhustle 0 2,477 09-16-2022, 10:06 PM
Last Post: nixyhustle
  Does anyone know how to install levinsboot on pbp? computerc 0 1,981 09-05-2022, 03:52 PM
Last Post: computerc
